Old 08-31-2012, 07:50 PM   #11
bikendan's Avatar
vcalder, just to clarify, Palomino should be dealing with the issue, since Palomino is an independent factory, under the FR corporate umbrella.
at least this is how i understand it, since FR acquired Palomino from Vanguard Industries, a few years ago.
same thing goes for the other recent acquisitions, like Dynamax, Viking, Shasta.
i would let C.C. look into it or call the factory.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 09-09-2012, 09:51 AM   #12
Trailer Trash
Originally Posted by Going Camping View Post
How do you correct the radio problems in the 320 RS. Volume will not work right nor does the radio pick up a good signal. Radio station is strong considering we are 5 miles from transmitter. Also unable to get IPod to play through radio with cable provided. Is there a quick fix or not.
2013 Columbus 320RS
2006 Dodge 2500 HD
Had the volume up down buttons die on me a couple days ago. I unplugged shore power AND put battery disconnect switch on the off position. In essence what I wanted to do was remove all power from basement radio. Turned on battery and AC power and sure as heck, volume buttons worked again.
Be advised one the radio is on, if you press the power button the radio goes into mute mode and display will show this. Volume buttons of course do not work in mute mode.
joelek is offline   Reply With Quote
