Old 04-24-2013, 09:03 AM   #1
BuckeyeChuck's Avatar
clearance
Anyone have problems pulling under the canopy that covers the gas pumps at most gas stations?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 04-24-2013, 09:23 AM   #2
treaves's Avatar
Are you asking if most canopies are high enough for 5th wheel trailers?
treaves is offline   Reply With Quote
Old 04-24-2013, 09:29 AM   #3
It is always a concern and something you need to check every time you gas up.
Old 04-24-2013, 09:33 AM   #4
My guess is you'll only have a "problem" one time!!
mogman is offline   Reply With Quote
Old 04-24-2013, 01:22 PM   #5
Just wondering about that. I realize that you have to check carefully before proceeding Under them. Just wondering what others experience was
2013 Sabre 33CKTS
Old 04-24-2013, 01:52 PM   #6
Oakman's Avatar
I guess you're asking because you have a gasoline engine in your tow vehicle. If you have a diesel engine then use the truck pumps at travel centers and truck stops where canopies are high enough for the big rigs.
My previous truck had a 8.0 liter gas V10 engine that averaged 6 MPG when towing. On long road trips I'd have to make stops for gas a lot. Generally speaking almost all gas stations along the interstate highway system will have a canopy tall enough for your fifth wheel to fit under. Of the ones I encountered that were too low for my Wildcat they all had the height of the canopy marked.
There are still some older stations along state and county roads that have low canopies. From what I've seen most of the low canopies are obviously too low for the fifth wheel. If you are in doubt have whoever is traveling with you spot you as you slowly drive under the canopy.
Look for travel centers to gas up, I've yet to see one that didn't have a high canopy. Also when we traveled along the interstates I would only fuel up at exits that had more than one station. I always looked for stations that had easy in and easy out access.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-24-2013, 02:01 PM   #7
Thanks. That's the kind of information I'm looking for.
2013 Sabre 33CKTS
