You will probably need a " Pulse width modulation " dimmer. It will turn the led on and off rapidly to dim the light, more off than on the dimmer you go. A voltage dimmer (potentiometer) will actually sometimes damage an led and also sometimes just wont work. Leds are an, on or off, light......not really dimmable like a normal halogen type bulb.
Good luck!
