Old 01-08-2013, 09:37 PM   #11
Originally Posted by joelek View Post
Same drill with mine. Also the kitchen and hallway lights lower or kill reception on the basement radio. So today I Googled LED lighting radio interferance. On a ham radio website forum I found that the LED lights do indeed emit RF noise. One guy flipped the polarity on his LED light and problem went away - The LED light was not polarity dependant in the socket. SOOOOO, flip your lights in the socket and see what happens.
IF that doesn't work, get creative with RF shielding. Thin copper film plates aka copper tinfoil is used inside of electronic equipment enclosures to reduce/eliminate RF noise emmisions from the electronic device. Playing with this material may also help.
It's winter in Minnesota. It's gonna be awhile before we do any testing up here in the great white north.
Regarding TV reception.......the bedroom TV has a setup menu that allows you to view the antenna signal. Get to this menu then rotate your roof antenna to adjust for best signal reception.
Hi Joelek!
We will investigate the LED issue and see if there is something we can do.
When you talk about the TV reception and the 'set up menu' are you reffering to the scan that is done off the menu=channels=auto channel search, then it locates the available channels? Or is there something else I am missing? We have the Hisense TV BTW.
Thanks!!
Larry & Kerry Jackson
2012 Ford F250SD
2013 Columbus 320RS
Kerryj is offline   Reply With Quote
Old 01-08-2013, 10:32 PM   #12
amxpress's Avatar
My Columbus 320RS was built in March 2012.
If I turned on the LED lights over the TV or stove, the TV picture would go out when using the roof antenna.
Here's what I would recommend doing:
Remove the antenna amplifier plate located behind the TV.
Make sure the coax cables are all tightly screwed into the amplifier. Also, make sure the coax terminals are tight on the cable ends. Mine wasn't. It is now and my TV works great with the antenna.
Finally, make sure ALL the coax cables are connected to the amplifer. The cable running to my roof antenna was not connected AND the terminal end was loose.
Good luck.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 01-08-2013, 11:12 PM   #13
Good luck.
Thanks amxpress! I will give that a look tomorrow hopefully and see if it works! I will post if something works!!
2012 Ford F250SD
2013 Columbus 320RS
Old 01-09-2013, 12:42 AM   #14
ranchand
Amxpress, my Columbus 320 was built in June of 2012 so I will check the cable connections. Is the antenna amplifier behind the amplifier wall plate? Thanks for sharing your experience regarding this issue.
ranchand is offline   Reply With Quote
Old 01-09-2013, 05:55 AM   #15
Trailer Trash
Originally Posted by Kerryj View Post
Hi Joelek!
Thanks!!
Not the Hisense tv in living room as I never found this feature on the Hisense brand. Use the bedroom TV - mine is a Toshiba. Not the scan for channels menu either. There is a setup menu for checking/displaying antenna reception. Sorry I don't have the how to get to this setup feature memorized so you will have to play with it yourself.
joelek is offline   Reply With Quote
Old 01-09-2013, 06:48 AM   #16
Herk7769's Avatar
The wall plate is a power supply for the amp which is part of the antenna on the roof (inside the white box). It is also a powered switcher that switches the TV feeds to the roof antenna when ON and to the cable TV connection on the outside of the camper when "OFF."
Lots of connections back there to check including the splitters.
HAM CALLSIGN - KC3FFW
Old 01-10-2013, 01:25 PM   #17
rugmanrn's Avatar
We had the exact problem. Turn on the lights, Especially the switch on slide near LR tv, and we would nearly lose tv reception on cable. It would be one of watching DVD. After 2 days of trouble shooting by the tech on site it was found that none of the screw on connectors were grounded. The factory just screwed on the connectors without stripping some of the insulation back and exposing the silver mesh of coax. After replacing all the ends it works perfect. We ha to remove panels underneath Rv and find the male-male connector. Forest river rep Bryant is aware of this. I sent home pics of the way factory did connectors
rugmanrn is offline   Reply With Quote
Old 01-10-2013, 01:26 PM   #18
rugmanrn's Avatar
Also. Our unit was built in March 2012
Old 01-10-2013, 07:59 PM   #19
ranchand
Thanks herk7769 for posting the information regarding the antenna amplifier. When I get time I will check the connections behind the wall and see if coax connections are good.
Old 01-10-2013, 08:06 PM   #20
Rugmanrn, was the work the dealer done in reworking the coax connections covered by factory warranty? Sounds like I may have the same issue with my tv and LED lighting. I lose tv signal when some of my light switches are turned on. Have Columbus 320 built June 2012
320rs, reception
