Originally Posted by herk7769
Coax cable is shielded and should reject any interference PROVIDED the shielding is intact from one end to the other. If the shielding was damaged when pulling the wires through the duct work or the ends are poorly made (a chronic manufacturing problem as folks who have had Concertone problems can testify) the shielding can allow RF interference from AC or DC sources to overlay the digital signals.
I would check your cable ends for good termination connections.
On my 295RL I have found 6 bad cable connections and fixed them all. They use these twist on connectors but whomever is installing them at the factory does not know what they are doing. I have not noticed the problem that everyone is talking about but I have not been paying attention as I have only been watching movies because the reception has been so poor. We will see in the spring if it has made a difference.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
