Old 12-17-2014, 12:08 AM   #1
columbus 320 vacuum
Hi; I am having difficulty removing the step off, to gain access to the vacuum, removed all the screws and the tread will not move,also the vacuum is a a eureka yellow jacket brand,it will not shut off, I turned off the breaker to turn off, also disconnected the 2 wires at the hose connector, and it still runs, any suggestions
bigfiver is offline   Reply With Quote
Old 12-17-2014, 11:54 AM   #2
Cyoul8r's Avatar
I was told by Sabre Sam, who used to be the Sabre rep on this forum, that in addition to the screws the steps are also glued down. Probably to prevent FR liability. As far as your vacuum not shutting off ... does it shut off when you turn off the main breaker? If so, it seems that your breaker could be mislabeled.
2012 Palomino Sabre 32RCTS-6
2012 Ford F-250 Super Duty Fx4 6.7 Powerstroke
16K PullRite SuperGlide
Air Lift LoadLifter 5000 Air Bags
Cyoul8r is offline   Reply With Quote
Old 12-17-2014, 12:52 PM   #3
skipperW's Avatar
The step is held down with double sided carpet tape as well as the screws.
2013 Columbus 320RS
2013 Ram Laramie Longhorn 3500 Dually 6.7 Cummins
Days Camped 2013 - 50
skipperW is offline   Reply With Quote
Old 12-24-2014, 08:07 PM   #4
I had the same issue. If still under warrantee, the manufacturer will replace.
Mozzy n Boob is offline   Reply With Quote
Old 12-25-2014, 11:03 AM   #5
Infractee
Check to make sure the two trigger wires are not touching right where they attach to the vacuum. Also, disconnect the trigger wires where they attach to vacuum and try again. Are there any other inlets, like a dustpan? If so check the trigger wires going to it as well. The control board/relay could be stuck on, killing the breaker and resetting it may reset the relay as well.
RhoZeta is offline   Reply With Quote
columbus
