Old 10-14-2012, 02:30 PM   #31
Summer storage?
I have a 365RL being delivered to Florida on Dec. 1st. I'll stay in it till April 1st
than close it up till the following Nov. Any tips or suggestions for this type of storage will greatly be appreciated. I plan on getting a cover for it to protect it from the sun and rain, but I'm not sure what else I should do. I know this is the opposite of what this thread is about, but thought I would throw it out there,thanks.
WRROST is offline   Reply With Quote
Old 10-14-2012, 03:08 PM   #32
Ok I figured it out. The factory did not put the silver strain into the port so it was not actuation the check valve on the winterizing port. I took the strain off the black water flush and Wallace. However (and this is based on myrevious units where I had to take off one side of the pump to winterized) I noticed that the pressure to pump the antifreeze was very low. Also I only used about 2 gallons of anti (and yes I got everything including outside shower and washer dryer. Any comments?
dkwin1 is offline   Reply With Quote
Old 10-14-2012, 08:08 PM   #33
Camper Couple's Avatar
Where do you get the hose to suck the antifreeze with? Did you just use a piece of hose? Our old camper had this clear plastic hose.
2013 Columbus 320 RS
2008 Chevrolet Diesel 2500 HD
Camper Couple is offline   Reply With Quote
320rs
