Old 02-02-2014, 06:08 PM   #1
Rmk2001800's Avatar
Columbus 365rl mod's
What kind of mod's have people been doing with them- just looking for some ideas....
Rmk2001800 is offline   Reply With Quote
Old 02-14-2014, 05:23 PM   #2
A 365RL is gorgeous the way it is, but we have customized ours just a little and it's all in the towing or handling of it. We upgraded the pin box to the Trailaire Tri-Glide. It really helped with the chucking.....the push pull fight between the camper and out Dodge Ram. We also added a shock kit to the axles. This tamed the camper and thus reduced the tug of war associated with pulling a camper. One more thing, I guess I also added a 2 gallon expansion tank next to the water pump. The water pump runs very little because of the expansion tank and you can't hear the pump run either. Hope that all helps.
mvolnek is offline   Reply With Quote
Old 02-15-2014, 05:06 PM   #3
hihocarp's Avatar
We have ordered the same trailer and I was wondering about this expansion tank you installed. Is it one that you can pressurize with an air hose? Also wher is the pump on the 365' is it in the storage compartment or in the trailer itself?
2012 Dodge Ram 3500 Crew Cab Dually
2015 Columbus 365 RL ( completed April 14,2014 )
Baxter and Bella [our dogs]
Days camped in 2014: 7
hihocarp is offline   Reply With Quote
Old 02-15-2014, 07:23 PM   #4
Rmk2001800's Avatar
Here is my list- and I have not even got the trailer but all the supplies to complete.
Rear hitch
Rear rack for generator
Slide out TV mount for basement - 46" led
Grill mount to front leg- with quick connect and T splitter for LP
Winngaurd satellite with SWM switch
Not sure what to fabricate next????
Old 03-09-2014, 09:31 PM   #5
What dodge ram do you have for pulling this unit?
2003 Ram 3500 quad cab 5.9 turbo
Smarty JR, exhaust brake, air bags, 20K Pullrite auto slide
Columbus 36RL
fivweight is offline   Reply With Quote
Old 03-10-2014, 10:45 PM   #6
Python15's Avatar
Will the basement storage hold a 46" tv? I measured for my 340 rk that's not in yet and I got that it will only hold a 32"?
Python15 is offline   Reply With Quote
Old 03-10-2014, 11:44 PM   #7
SYE
SYE's Avatar
Mine will not fit a 46 inch!!!
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 03-12-2014, 07:31 PM   #8
Rmk2001800's Avatar
Name:	ImageUploadedByForest River Forums1394670681.084952.jpg
Tv installed...
Old 03-12-2014, 07:40 PM   #9
Python15's Avatar
What size tv? Send me a picture of tv bracket pleeeease.
Old 03-12-2014, 07:49 PM   #10
Rmk2001800's Avatar
60 bucks in steel and I fab it up myself
5' 2" sq tube
3' 1.5 sq tubes
3/4 round stock
5' 2" flat stock to raise 4" off floor
Machined slot in 2" so 3/4 round stock could slide through
Name:	ImageUploadedByForest River Forums1394671667.221807.jpg
ID:	47603Click image for larger version
Name:	ImageUploadedByForest River Forums1394671683.907827.jpg
ID:	47604Click image for larger version
Name:	ImageUploadedByForest River Forums1394671703.108498.jpg
ID:	47605Click image for larger version
Name:	ImageUploadedByForest River Forums1394671710.598602.jpg
Old 03-12-2014, 07:50 PM   #11
Rmk2001800's Avatar
Also I can take better photos in the day light.
Old 03-12-2014, 08:02 PM   #12
Python15's Avatar
Looks awesome really need pics of bracket and size tv.
Old 03-12-2014, 08:07 PM   #13
Python15's Avatar
Is your basement storage larger than the 340 rk? I measured and I am almost positive 32" is largest I can get in there. Am I missing something? Help me out. sferg15@icoud.com
Old 03-12-2014, 08:11 PM   #14
Rmk2001800's Avatar
365 has the dropped frame- 32 don't so there is a step in ur basement where mine doesn't have one
Old 03-12-2014, 08:17 PM   #15
Python15's Avatar
Thanks for all your help.
Old 03-12-2014, 08:31 PM   #16
Rmk2001800's Avatar
Wind guard carry out
Old 03-12-2014, 08:40 PM   #17
Python15's Avatar
Dish or direct does it get the sats fast? Hd?
Old 03-12-2014, 08:43 PM   #18
Python15's Avatar
How many receivers? Wearing you out yet
Old 03-12-2014, 08:48 PM   #19
Rmk2001800's Avatar
Directv- you only need to find 1 sat then- with dish u get hd but have to have it lined up to 3 sat. Just my opinion.
3 receivers- I pull 2 from the house on extended stays. I had to add a swm from direct so I only have to run 1 cable from the sat. About 30 bucks on eBay.
And nope I'm not worn out- I like talking shop to much
Old 03-12-2014, 08:49 PM   #20
Rmk2001800's Avatar
And very easy to get signal- I have an app on my phone that it shows where the sat is that u need to line up with. Then u can see if there is anything in ur way
365, columbus, modifications
