Old 06-03-2013, 05:35 PM   #11
Jimmerinwi's Avatar
Originally Posted by cpaulsen View Post
You can use a splitter with Dish....I am using one right now. They have to be made for satellites. I use 1 cable from my Dish 1000.2 to my 5ver.....then it is connected to a splitter with one cable to the bedroom and one to the living room. Use 1 Dish receiver which feeds both tv's independitly.
It's called a diplexer. Looks like a splitter but isn't. The diplexer allows2 tv's to run off a dual tuner receiver, TV 1 and TV 2, TV 1 is hd with a 622, 722 or 922 receiver, and TV 2 is standard def.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 09-04-2014, 04:29 PM   #12
I just bought a Tailgater to use with my Dish subscription. In the utilities box outside there is a satellite and a cable coaxial connection; however, inside the rig near the main TV there is an antennae and one other connection. I don't get it. Still loving my RS 320. Thanks.
cdrdevine is offline   Reply With Quote
Old 12-30-2014, 03:28 PM   #13
The labeling is awful. The correct satellite connection behind the living room TV is next to the ant/ cable F connector. The separate satellite connector is a direction connection to the bedroom TV. Us thus if you have a dual feed sat antenna to a second Rx in the bedroom.
seahawk986 is offline   Reply With Quote
