Old 10-08-2012, 10:49 AM   #261
thanks for the help -we checked the paperwork Sat. night...no luck. We might disconnect the battery & re-connect to see if that does anything.
We have had the time now to disconnect & reconnect the battery -WOW the furnace now works!!!!! Thanks for the help in other post.....this is a great site & I have learned so much. We are winterized, TV is in the house for our viewing pleasure on the off season and have planned some May, July, Sept camping already.
Cover comes this week so we should be closed down for the season by Halloween.
Now -how do we get fuel prices down so we can RV more in 2013????
thanks everyone for your assistance.
Barb
Barpat is offline   Reply With Quote
Old 10-08-2012, 08:22 PM   #262
Trailer Trash
RTFM = read the friggen manual.
Error Code:
E1 Loss of communication between the CCC 2 thermostat and all system power
module boards. System will shut down.
E1 Loss of communication between the CCC 2 thermostat and an individual system
power module board. The LED will display error code EI and the zone number
that lost communication. Any additional zones that loose communication will
blink in addition to the current zone.
E2 Open circuit or out-of-range indoor temperature sensor. All heat , cool, and dehumidify
operations will be locked out. Manual fan operation will continue.
E3 Shorted Indoor Temperature Sensor. All heat, cool, and dehumidify operation will
E4 Open circuit or out of range Outdoor Temperature Sensor (select models). Heat
pump and dehumidification operation will be locked out. Air conditioner, furnace,
heat strip and fan operation can continue to operate.
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
can continue to operate but displays the last temperature set-point.
E6 Open circuit Humidity Sensor (Select Models). Air conditioner and dehumidification
will be locked out. Heat pump, furnace heat strip and fan can continue to
operate.
E7 Loss of 120 VAC power to all power module boards on the system. The system
will shut down.
E8 Invalid zone configuration. The heat pump and heat strip DIP switches are both
set to the ON position in one zone. Heat pump, heat strip, air conditioner, and
dehumidify operation will be locked out in the affected zone.
E9 Invalid zone configuration. The dehumidifier DIP switch and either the heat pump
or heat strip DIP switches are set to the ON position in one zone. Heat pump,
heat strip, air conditioner, and dehumidify operation will be locked out in the affected
zone.
When your unit was installed the appropriate dip switches on the electronic control
board were turned on to match your system configuration. Any time these settings
are changed, a system reset will need to be done before the CCC 2 thermostat will
recognize the updated selection. To do a system reset:
• Make sure the CCC 2 thermostat is in the OFF mode.
• Simultaneously press the
MODE and ZONE buttons. The LCD will display
“IniT” and all available zones.
• Release the
• Press the
ON/OFF button to exit system set up.
joelek is offline   Reply With Quote
Old 10-08-2012, 08:30 PM   #263
Trailer Trash
I only have 1 air conditioner instead of 2 so I did a system reset. My thermostat only shows control for zone 1 now. Factory default was 4 zones. Getting rid of the zones you dont have may help with communication errors in the future.
Old 10-08-2012, 08:39 PM   #264
Earth Station's Avatar
We are already making plans for 2013. Three trips left this year!!! Possibly two dry trips over the winter if the weather cooperates!!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 10-09-2012, 08:53 PM   #265
Awesome -thank you so much...printed & in the Columbus 320 RS!
Old 10-09-2012, 09:18 PM   #266
john I
johnemt's Avatar
Originally Posted by radarmile View Post
I've read a lot on here about the black water flush being hooked up wrong. The guy that pumps out our tanks says we get almost no flush. How can I identify if mine is connected wrong and how do I make it right? I took off the wall behind the service panel. From the waste tank flush, it goes forward a couple of feet and goes up. Does it go up into a check valve and then down to the tank?
Also, as I asked above, when I bypass my hot water tank and switch to winterization, does that put the suction side of the pump to the winterization hose connection? I don't know about anyone else, but my book is very vague, covering campers in general. Doesn't really cover my unit. Any help would be appreciated.
I have a 365 rl that had the same problem,frist time i hooked it up i did not hear water passing through. It turned out that the check valve was in backwords. My dealer fliped around and now working good.
John I
2012 Columbus 365RL
2012 Dodge Ram 3500 6.7 cummins
1963 5'2" wife Sheri
johnemt is offline   Reply With Quote
Old 10-09-2012, 09:40 PM   #267
john I
johnemt's Avatar
Originally Posted by 1jeb289 View Post
Try checking the manual for the thermostat control It will have what the E1 code means and give you a starting point for the problem
E1 means the t-stat is not seeing power to the furnace,check your 12 volt fuses. IF no blown fuse check to make sure you are on the right zone.
John I
2012 Columbus 365RL
Old 10-10-2012, 07:43 PM   #268
Trailer Trash
Look in the PILE of manuals that came with your RV. The Dometic thermostat manual should be in there. It's a small booklet format.
What I and many others do, is find the manuals for each device and appliance for our RV, download them, store them in folders for each appliance and device on computer. Makes finding things easy in the future. You have to know brand, model #, etc. to be able to do this but with google, it's pretty easy.
Old 10-10-2012, 07:49 PM   #269
If you have an ipad, and can get your manuals in pdf format, then you are all set with the perfect solution.
I have many, many manuals and technical publications on my ipad for quick reference. To get them in there, you simply email them to yourself and save them to your ibooks.
crasher is offline   Reply With Quote
Old 10-11-2012, 07:28 AM   #270
Now Camping Year-Round!!
WannaBcamping's Avatar
Excellent idea wincrasher. When the time comes this spring, I'll be doing the same!
Cathy & Fraser - Ontario, Canada
2017 Rockwood ML 2507S
2013 Columbus 325RL -parked in Florida
2011 Ford F250 Super Duty Diesel King Ranch
2011 Rockwood Roo 21RS
2009 Wildcat 29RLBS
WannaBcamping is offline   Reply With Quote
5th wheel
