Old 05-02-2013, 11:18 AM   #1
Columbus 5ver mods
Since purchasing the new Columbus 5th Wheel a few weeks ago, I have been extremely busy "making it ours". This is a list of the projects that have been working on since she came home.
Well, the list of upgrades/changes on the 320RS is growing. So far I have installed an exterior WiFi antenna with router and power booster, added a crank up satellite dish to the roof, added a Splendid washer/dryer combo, added a 1000 watt inverter, changed out all of the day/night blinds for roller shades, unscrewed the satellite cable wiring from the factory, added an Onan 5500 watt generator, added a slide mount TV to the storage bay with DVD player, and added a hardwire 50 amp surge suppressor. I still have coming a transfer switch to go between the inverter and the power panel, and am changing out the Trump mattress for a Sleep Number air mattress.
And that doesn't include the upgrades and changes to the tow vehicle. Adding the 5th wheel hitch, transferring the TPMS system into the truck, adding a pair of Air Lift air bags to the rear, moving the location of the 7 pin connector from the bumper to the left rear side of the bed, and finding a suitable mounting desk for the DW computer to run the MS Streets and Trips while we go down the road.
Whew, I need a vacation...........
SargeW is offline   Reply With Quote
Old 05-02-2013, 12:15 PM   #2
semi-senior member
denandra2's Avatar
What a list. Sounds like you should have just checked all the options on the list and then some!! But you're having fun,Right?
Dennis & RuthAnn
Tippy too!
Columbus (2014)320RS
2014 Ram 3500 DRW 6.7HO
Aisin 6speed Auto
SE Mo
denandra2 is offline   Reply With Quote
Old 05-02-2013, 02:27 PM   #3
You've been busy Sarge! Now get out there, go camping, and put all those mods to good use, you deserve it.
Old 05-02-2013, 03:37 PM   #4
Actually I love doing as much stuff on the rig as I can. That way I know that it's done the way I like, and I learn something in the process.
Old 05-02-2013, 07:05 PM   #5
treaves's Avatar
Where did you get your generator from, and did you get the prep with the trailer?
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 05-02-2013, 07:06 PM   #6
treaves's Avatar
What external WiFi antenna and booster did you go with?
2014 Columbus 320RS
Old 05-02-2013, 08:45 PM   #7
The generator I got from Craigs List. It came from a toy hauler that burned up. The trailer already had the Gen Prep on it. The WiFi antenna is a Wilson Shorty RV antenna. It's connected to a router and a Wilson power booster. The set up works pretty well.
Old 05-02-2013, 08:53 PM   #8
treaves's Avatar
Thanks for the info. The only Wilson stuff I find is for cell, not wifi; would you have model numbers?
2014 Columbus 320RS
Old 05-03-2013, 01:04 AM   #9
Here is a link to the antenna I have, purchased from 3G store.com. It is a dual band antenna that does broadcast cell signal, in this case from my Verizon modem. Omni RV 3G/4G Antenna with Spring Base, 21 Inches, 9 Reviews : 3Gstore.com
Old 05-03-2013, 07:21 AM   #10
treaves's Avatar
Ah, So it's not WiFi antenna and WiFi booster, it's cell. Thanks for clarifying that.
2014 Columbus 320RS
