Old 07-16-2015, 11:29 AM   #1
NewBee
Send a message via Skype™ to TheRamaraos
Columbus cell phone charging station problem
Dear forum members
Any ideas as to where we can get a replacement dual USB charging adapter for a 12V supply for our cell phone charging station. Can Forest River ship us a replacement as our unit is still under warranty till Feb 2016. Our USB charging ports are not working, but the cigarette adapter is working just fine. SInce the USB charging ports draw power from the same source as the cigarette lighter adapter, I have concluded it is the USB adapter itself.
Balaji
The Ramaraos (Balaji and Indhu)
New to this lifestyle and have tons of questions
2015 Palomino Columbus 340RK
2015 Chevy 3500HD SRW Duramax with Alison
TheRamaraos is offline   Reply With Quote
Old 07-16-2015, 11:45 AM   #2
B and B's Avatar
Hello,
My USB did the same thing. Have you removed power entirely to rest it? The battery cut off switch?
Brian
B and B
Old 07-23-2015, 09:00 PM   #3
They replaced the charging station on my 320 for the same reason
kssportsman is offline   Reply With Quote
Old 07-23-2015, 09:22 PM   #4
Flybob's Avatar
The chip used in most USB chargers has a protective mode built in. If it is shorted or draws too much current, it will shut down. To reset it, simply remove power from it. ( in your case unhook from RV ) wait 10 seconds and reconnect you should be ok.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-23-2015, 11:36 PM   #5
NewBee
Cell Phone Charging Station
Thanks folks. I tried the battery disconnect. Did not wait for 10 secs, so will try that again. If that does not work, let me see if there is a way to disconnect it without having to replace the connectors. The ones that are used in my RV are the clamp on types, and I typically use the twist one type. If I have to disconnect the wires, it means cutting, stripping and reconnecting.
Thanks again,
Balaji
Old 07-24-2015, 02:03 PM   #6
You can get them on Amazon for $12. I replaced mine in 5 minutes and it works great now. I replaced the 12 volt charger with another USB charger so now we have four ports. Works great!
Amazon.com: XYZ Boat Supplies Dual USB Charger Socket for Boat / Rv / Car / Motor-home (Black): Sports & Outdoors
HappyCamperCY96 is offline   Reply With Quote
Old 10-02-2015, 10:19 PM   #7
Swift2
Swift 2's Avatar
Name:	ImageUploadedByForest River Forums1443841936.790339.jpg
ID:	90507just changed mine this week. I got it from Amazon. Upon inspection I found that it is a slide in and out unit which pulls out, no need to get into the wiring. The wiring on the back of the unit just has appliance lugs and would be easy to remove if you decide to replace the entire unit. Lots of luck.
Swift 2 is offline   Reply With Quote
charging, columbus
