Old 03-05-2016, 07:46 PM   #1
Columbus compass awning issue
My in laws just purchased a columbus compass 381, they are out with it for the first time and can't get the awning out. It has a metal cover that doesn't seem you raise when trying to deploy. The awning just starts to unroll within it.
KIPKERS is offline   Reply With Quote
Old 03-06-2016, 11:25 AM   #2
The awning arms are probably stuck together. try starting the awning out a little and then pull the arms apart. If that works put a little silicone lube on the arms where they slid together.
Okie
Okie
Retired USMC&FAA
2015 Columbus 381FL
08 F450
USMC Okie is online now   Reply With Quote
Old 03-15-2016, 07:43 PM   #3
Isn't electric?
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 03-15-2016, 08:13 PM   #4
Yes it's electric, when you press the awning out button it's starts unrolling but won't extend out until you manually list up in the metal cover
Old 03-15-2016, 08:35 PM   #5
Originally Posted by KIPKERS View Post
Yes it's electric, when you press the awning out button it's starts unrolling but won't extend out until you manually lift up in the metal cover
If you can't get the dealer to fix it, you might have to remove it and re-curve it. Pictures would sure help.
Old 03-15-2016, 08:37 PM   #6
Rupkin2's Avatar
the black knobs on the arms may still be tight.
Check them and loosen them if necessary.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 03-20-2016, 10:55 PM   #7
SYE
SYE's Avatar
It doesn't matter if the knobs are tight or not, you can open it or close it where ever they are
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
awning, columbus
