Old 06-23-2019, 10:08 AM   #1
Ccfd48's Avatar
Columbus Compass Crack in side of wall
Our compass has developed a crack by upstairs bedroom slide. How do you fix this? We have a extended warranty who can fix it? Has anyone else seen this before?
Ccfd48 is offline   Reply With Quote
Old 06-23-2019, 10:11 AM   #2
Ccfd48's Avatar
Trying to add a pic
Old 06-23-2019, 10:12 AM   #3
SeaDog's Avatar
If you are still under warranty have a professional fix it. If it was out of warranty I would stop drill the crack.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-23-2019, 12:01 PM   #4
SYE
SYE's Avatar
In our Columbus group many have had the crack, in fact we found 2 of our members have cracked in the living room walls on a 366 1492
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 06-24-2019, 12:19 PM   #5
A crack below the bedroom slide in a corner is pretty common, they just need to put in a stress relief strip from the corner to the bottom of the side of the trailer. On some models there is not enough meat on the bottom side to withstand the flexing of the RV. A dealer should be able to do that for you.
Bigruh36 is offline   Reply With Quote
Old 07-02-2019, 08:50 PM   #6
I have the same problem. Upper bedroom crack at slide bottom. Click image for larger version
ID:	208786Click image for larger version
RPCP is offline   Reply With Quote
columbus, crack
