Old 01-21-2013, 05:23 PM   #1
Columbus construction details
I'm looking for more detailed information regarding the construction methods of the Columbus 5th wheels.
Is it similar to the Cedar Creek 16" OC aluminum stud method? Or is it a solid laminate within the aluminum frame?
Are cut away photos available detailing the construction?
The Palomino web site is rather vague:
100" Wide Body
All Welded Aluminum Frame
5-Sided Lamination plus Front Cap
6" Radius Roof w/ Laminated Block Foam
6' 6" Height (Living area slides)
(5) Heat Ducts Out of Traffic Areas
Snap-in Ceiling Molding -
No Staples or Tape
12-Volt Heat Pads on All Holding Tanks
Laminated Floor w/ Astro-Foil Insulation
R-32 Floor Insulation
R-30 Roof Insulation
R-9 Sidewall Insulation
sidney is offline   Reply With Quote
Old 01-21-2013, 05:57 PM   #2
I just downloaded the Columbus brochure and there wasn't a cut away view anywhere.
Old 01-21-2013, 06:44 PM   #3
Commercial Member
huntr70's Avatar
100" Wide Body
No Staples or Tape
Actually, your description above, covers it....."5-Sided Lamination plus Front Cap" is exactly what it is. Roof, floor, rear wall, and both sidewalls are laminated. That means welded aluminum framing, rigid foam insulation, and interior panels are bonded as one piece.
The Cedar Creek uses 16" on center aluminum studs and hung fiberglass and interior panels. Also batted insulation, which can compact over time.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
huntr70 is offline   Reply With Quote
Old 01-21-2013, 07:19 PM   #4
Send a message via ICQ to ByronCR Send a message via AIM to ByronCR Send a message via MSN to ByronCR Send a message via Yahoo to ByronCR Send a message via Skype™ to ByronCR
I know where Sidney is coming from in requesting some more specific information. A majority of the 5th wheels brochures I had looked at (which was over 30) had cut away diagrams showing the constructions layers of how the RV was built. It is very helpful for people that are more visual than text based. I am one of those that totally gets it on paper, but a visual eliminates any misconceptions.
A cut away view would be nice, but the brochure does give ample information on the construction of the Columbus.
Byron R
2013 Columbus 295RL
2006 F350 6.0L Crew Cab LB SRW
ByronCR is offline   Reply With Quote
Old 01-21-2013, 09:39 PM   #5
Thanks for the replies but I still find the description very vague.
What materials are used? OSB, Plywood, Marine plywood... tongue and groove? 1/4", 3/8", 5/8" ?
The roof must have trusses... are they aluminum, wood... what are the dimensions? How are they spaced? What is the exterior roof material?
What about the floor joists? Wood, aluminum... what's the spacing? What is the floor base decking material? OSB? Plywood? T&G?
What are the laminated wall components? How is it manufactured?
There are many details missing in the description of the construction.
Old 01-21-2013, 10:04 PM   #6
Oklahoma Proud
MillerTime's Avatar
I don't know much about most of your questions, but I know on some if the palamino line the floor is one solid piece of plywood and I believe it is 5/8".
Ps maybe a call to the factory or the factory rep might help more.
Old 01-21-2013, 10:15 PM   #7
dan747's Avatar
Construction details
I agree with you on the lack of construction cutaways. I would have liked them too. I asked the rep at the show about the details you asked about and this is what he said. Aluminum roof trusses with 6 inch thick(at the crown) solid foam insulation and plywood decking(I don't remember the thickness), plywood-foam-aluminum bonded floor(I don't remember the thickness). Christopher Columbus is associated with Columbus and posts on here and would have better details then me so hopefully he will see your post and respond.
Dan & Trish
2006 F-250 Lariat 6.0 Powerstroke
2011 Prime Time 260rld Crusader
Columbus 320RS on order
dan747 is offline   Reply With Quote
Old 01-21-2013, 10:42 PM   #8
Grape Escape
If that is true I'd beware of bonded floor. I have a section on my Cardinal in the bathroom (the only place in the whole coach) and it squeeks like crazy. It feels as if it's separated
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 03-20-2013, 12:15 PM   #9
treaves's Avatar
I'd b interested in getting an 'official' response as well. Anyone try just e-mailing Palomino directly?
treaves is offline   Reply With Quote
Old 03-20-2013, 04:08 PM   #10
dt82153's Avatar
My Wife and I have ordered a 295RL. I have emailed Palomino and Columbus several times and got no reply. I even called and left a message and no return call.
dt82153 is offline   Reply With Quote
Old 03-20-2013, 06:25 PM   #11
SYE
SYE's Avatar
Send a message to 'Christopher Columbus" on this forum, he is a factory rep of some sort. He would probably be happy to answer those questions.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 04-04-2013, 09:03 AM   #12
It would be nice to have those questions answered here as I'm sure others will ask the same question at another time.
Case in point: I'd like to know how much and what insulation is in the slides. I keep checking the website to see if this information has been added, but it's not. If there is a Columbus rep at our fall Hershey, PA RV show, I can ask then I suppose.
TV: '03 F350, Bulletproofed 6.0, SCT chipped
TV Nickname: Beastie Boy
miboje is offline   Reply With Quote
Old 04-04-2013, 09:12 AM   #13
SYE
SYE's Avatar
Go there and take a factory tour. They will probably answer all your questions.
Scott & Vicki
Old 04-04-2013, 09:22 AM   #14
That would be nice, but Hershey will be a lot closer for us, and we wouldn't be missing work to go. This type of information is often provided on manufacturer's websites, as well.
Old 04-04-2013, 11:04 AM   #15
SYE
SYE's Avatar
Go to the thread called ideas?? Christopher Columbus started this asking for input for Columbus
Scott & Vicki
Old 04-04-2013, 03:45 PM   #16
Update: I contacted Christopher Columbus, and they are working on getting a construction cut-away completed.
Old 04-06-2013, 09:17 PM   #17
john I
johnemt's Avatar
well if you go to the columbus web page there is a box lower right in that box there is tab you can click that says"MORE FEATURES" that will give a break down of construction
John I
2012 Columbus 365RL
2012 Dodge Ram 3500 6.7 cummins
1963 5'2" wife Sheri
johnemt is offline   Reply With Quote
Old 04-07-2013, 07:40 AM   #18
Thanks for posting that. Though I was aware of that, it will be helpful to those who didn't know. I was looking for a cut-away, which is much more detailed.
Old 04-07-2013, 07:53 AM   #19
treaves's Avatar
I'd be surprised if anyone wasn't aware of that, their marking bullet points. There are two different ways to navigate there on the web site, and, it's also in their brochure.
I believe the original post was in regards to actual construction details, not marketing bullet points labeled 'construction'.
Old 04-26-2013, 09:29 AM   #20
I keep checking, but no construction cut-away is available yet. In the meantime, I've been PMing Christopher Columbus with questions. I haven't heard back from him the last two times. Not sure why, but it doesn't make a good impression and is not good for business, but maybe they don't need my business.
We are considering a Heartland Gateway vs. the Columbus. I've been in contact with the Heartland Gateway sales manager, both by phone and via email, and not once has he not replied to me, and he has done so in a very reasonable amount of time - as in a matter of hours. That sure does make a good impression.
