Old 02-10-2013, 04:02 PM   #11
Grape Escape
LED lighting is nothing but a con as far as i'm concerned. Bought all new xmas lights and they are no better if not worse than incandecent bulbs at 10x the replacement price.
Saw replacement bulbs at RV show and at 18$ apiece I think I'd rather add a second battery at a much lower cost if I were worried about extending battery life IMHO.
Rather spend 99cents to replace bulb rather than ???
2008 Cardinal 30RKLE 5th wheel sold
2006 Rockwood 2607, 2001 Traillite
55 nights 2009, 53 for 2010
44 for 2011, 38 for 2012, 35 for 2013, 51 for 2014
dezolen is offline   Reply With Quote
Old 02-10-2013, 05:59 PM   #12
Columbus 302 rs
Thanks everyone, I will contact our dealer about replacements. I'm baffled as to why they are failing. As Herk said, usually electronics fail quickly or go on for a long time.
I disagree about LED lighting not being a good idea; when you look at the lumens they generate versus power consumed they make lots of sense (if they last their expected lifetime).
TheEdge is offline   Reply With Quote
Old 02-11-2013, 06:32 AM   #13
Trailer Trash
We are all used to little red and green half globe shaped LEDs that were on circuit boards and yes those last a lifetime. Now LEDs are huge, super bright hi intensity, running lights, taillights, flood lights, room lights, etc. Once you crank that many watts and lumens via LED, I don't believe you still get lifetime longevity.
The LED room lights take less electricity to run thus makeing the tree huggers happy. This is a green movement thing so it sells well. The new thing with RVs at the show this year is LED eyebrows on the front caps. Makes your rig look like an expensive European import car. Well even Kia and Hyundai have that look now.
joelek is offline   Reply With Quote
Old 02-17-2013, 01:11 PM   #14
Not-so-Junior Member
VenturaBill's Avatar
Originally Posted by joelek View Post
Not yet but it's winter here in MN.
How do you get the thin round covers off?
On our 2013 Columbus the LED covers are made of glass and screw off in a counter-clockwise direction. I have attached photos showing the cover on and off.
Name:	LED lenses.jpg
How is it one careless match can start a forest fire, but it takes a whole box to start a campfire?
2012 F250 6.7L Lariat 4x4 long bed
2013 Columbus 295RL
1952 Blonde Nurse
VenturaBill is offline   Reply With Quote
Old 02-17-2013, 02:45 PM   #15
LKicklight's Avatar
Led's bulbs
Just replaced every inside light fixture with the correct LED Bulbs, all 24...love the light that emitted from the LED's...also have them in our tow truck, S-10 and Jeep Compass....the 24 led lamps cost me at total for twenty bucks including shipping...now that is a great deal...Here is a lamp in the Compass over then drivers console..In the process of changing all exterior running light bulbs on the Crusader as well...have not counted those yet, but the bulbs that I have purchased are six LED's per bulb...
LKicklight is offline   Reply With Quote
Old 02-17-2013, 03:18 PM   #16
Owner/Operator
RodeoGeorge's Avatar
Link to the source/vendor please?
RodeoGeorge
RodeoGeorge is offline   Reply With Quote
Old 02-17-2013, 03:32 PM   #17
Columbus 302 rs
I believe they quote 6000 hours on these bulbs, so not a lifetime but sure not 7 months of intermittant use.
Old 02-17-2013, 06:01 PM   #18
Trailer Trash
Who is "they"?
Love to know the mfg & part # as I see no reason to buy these at retail pricing.
They look like they are made the same way as those strip tape LED lights people are putting on the edge of their awnings. Those host tape carriers I'm betting are fragile and crack with vibration from towing. The actual LED itself is not burning out. Wonder if the tape and connections can be fixed via resoldering with wire wrapping wire. I used to do this 20+ years ago back before everthing was surface mount and solder paste. Example below.
Old 02-19-2013, 08:18 AM   #19
LKicklight's Avatar
LED's ON Ebay
Who is "they"?
Item title
Price
Shipping price
Qty
Item total 10pcs T10 194 921 W5W 24 1210 SMD LED White RV Landscaping Light Lamp Bulb ( 360547839756 )
Here is the Number of the units I purchase..put it on ebay should pull them right up..any questions, drop me a line..kick
Old 02-19-2013, 08:35 AM   #20
Columbus 302 rs
Thanks for the link, first I will go to the dealer, as I think these should still be under warranty.
320rs, columbus, lamp, led, light
