Old 07-30-2013, 08:39 PM   #31
New LED lights
I'm very interested in seeing if these are going to work for you..because I'm in the same boat! Please let us know.
jewwels is offline   Reply With Quote
Old 08-02-2013, 02:15 PM   #32
BigTJohn's Avatar
The "new LEDs" in the '14 model 320RS work great, no tv interference. Just wondering about the other 23 bulbs which are incandescent rather than LED??! Why not do those in LED FR?
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 08-02-2013, 02:35 PM   #33
Keep in mind that in the light bulb technology, the bulb consisted of one element in a vacuum bulb - not much to go wrong. The electricity made the element burn and the vacuum keeps it from burning up.
The LED lights have not only the LEDs (several of them per light) but a bunch of little electronic gizmos that keep the right amount of electricity going to the LEDs. Several parts add higher probability of a light to fail. LEDs are rarely the part that fails, but without all the other parts working, you get no light.
LEDs do not create as much heat as traditional light bulbs and therefore make more light energy for what electrical energy goes into them. And, since LEDs don't have a little element wire that can break, they can take vibration much better and will last longer. The problem is those pesky other electrical parts that are put on the board. If the manufacturer goes cheap on those parts, it does not matter that the LEDs are better - you get a broken light.
2012 GMC 3500 Duramax Crew Cab, SuperGlide 20k
2014 Cedar Creek 36B4, LP Onan, Level-Up, Trail-Air pin, electric fridge
Campwell is offline   Reply With Quote
Old 08-13-2013, 11:12 AM   #34
Kash76's Avatar
BigTJohn,
I am curious about these "new" bulbs. I have a Solaire travel trailer and am disappointed in the interference that the bulbs cause my television. Can I get new bulbs from Forrest River?
2013 Palomino SolAire 317BHSK w/Eclipse package using a ProPride 3P Hitch
2013 Ford F-150 Ruby Red SuperCrew 4x4 EcoBoost w/Max Tow, e-lock, Michelin LTX M/S2 tires, & Air Lift 5000 Ultimate w/Load Lifter
Campers: Me, DW, DD, DS
Nights camped: 2015 (4) as of 5/25 2014 (44) 2013 (26)
ProPride Review
Kash76 is offline   Reply With Quote
Old 08-13-2013, 11:32 AM   #35
SYE
SYE's Avatar
While at the Columbus factory last week, the tech told us that they are no longer using the LED light bulbs. They have replaced them with a fixture that the light is permanent in, If it burns out just replace the whole fixture. it is a new style bulb.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 08-13-2013, 11:43 AM   #36
Kash76's Avatar
And these new fixtures do not have the same interference problems?
ProPride Review
Old 08-13-2013, 12:18 PM   #37
SYE
SYE's Avatar
That's what they tell me
Scott & Vicki
Old 08-13-2013, 12:28 PM   #38
Kash76's Avatar
Will the manufacturer help a new 2013 owner or am I on my own?
ProPride Review
Old 08-13-2013, 03:20 PM   #39
SYE
SYE's Avatar
Maybe but you will need to ho through your dealer
Scott & Vicki
Old 08-26-2013, 10:54 PM   #40
Kash76's Avatar
Originally Posted by TheEdge View Post
Palomino sent me 10 new LED light fixtures to replace those that I've had fail. The new fixtures have the LED array integrated into the fixture itself instead of like the previous two pin type array. I need to plug one in and see how the lumens and color compare to the original fixture array. I do see that the LED's are much smaller than the original. I'll give an update when I see the result. Thanks to Palomino for replacing the old units.
Any updates?
ProPride Review
320rs, columbus, lamp, led, light
