Old 09-09-2012, 08:19 PM   #71
Happy camping. Enjoy your 385. Ours arrived in May and we love it. My wife still works so our trips are long weekends or a week. We look forward to month + trips in a couple of years.
BT Ramblers is offline   Reply With Quote
Old 11-22-2012, 03:58 PM   #72
Unhappy Schwinntek slides controller location???
Does any one know where the schwinntek slides control boxes are? We have a 385BH. We are camping and can not get driver side bunkhouse slide out. One side moves but the other does not, so it binds and hangs up. We tried pushing by hand but I can not move it. Any suggestions?
jlosurdo is offline   Reply With Quote
Old 11-22-2012, 04:51 PM   #73
Just got your message.
At the top of the stairs on the left at the edge of the bedroom you will find the light switch for the bedroom the HVAC and the button to run the slide in and out. It is clearly labeled. Its a toggle switch. Press out.
In the case of an emergency, the manual crank point should be on the front door side.
Hope this helps.
Old 11-22-2012, 04:55 PM   #74
Sorry, my bad. The bunkhouse slide controls are on the left side of the door going into the bunkhouse. They are toggle. In and Out. One is for the left and the other for the right. I am at home so I am doing this from memory. The top one is the left slide and the bottom one the right. Ensure that the door to the bunkhouse is closed or the right slide can hang up against the folding door. Note: I am referring to the drivers side as right and the passenger side as left.
Hope this helps.
Old 11-22-2012, 07:01 PM   #75
Schwinntek BH slide motor sync computer location?
Thanks for the quick reply. I am actually looking for the location of the computer board that controls the two motors synchronization. If they get out of sync it can cause the issue I am having. To reset it you push the mode button 7 times holding it for 5 seconds on the last try.
Any help finding that circuitry is appreciated. Happy Thanksgiving!
Old 11-22-2012, 08:37 PM   #76
Sorry. Can't help. Better check with tech support.
