Old 05-23-2016, 09:51 AM   #1
Elkhounds's Avatar
Columbus shade adjusting
We have the Columbus 320RS with the day/night shades. I know you are supposed to be able to adjust them but can't see how to get the valence off. I don't want to break that off so any ideas? I guess once I can get to the end of the shade I can adjust them so they go all the way up. Right now all but 2 work correctly. The 2 that don't stop about 2/3's of the way up.
2015 F-350 Platinum 6.7 PowerStroke
2017 Columbus 320RS
Elkhounds is offline   Reply With Quote
Old 05-24-2016, 08:54 PM   #2
tugboat369's Avatar
Push the night shade all the way up first then the day shade.
Camping from 2008, Life member Good Sam / KOA / iRV2
2014 Columbus 320RS
2011 Ford, F250, 6.7D, SRW
tugboat369 is offline   Reply With Quote
Old 05-25-2016, 06:31 PM   #3
Don and Elaine's Avatar
There is a plastic "bobbin type" piece that the line winds around at the bottom of the shades. If you add one additional loop onto that "bobbin, it should take care of your problems.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017, and 94 days in 2018.
Don and Elaine is offline   Reply With Quote
Old 05-26-2016, 10:04 AM   #4
Elkhounds's Avatar
Thanks. I'll take a look at it this weekend. I didn't know I could have both day and night shades down at the same time so I'll see what happens with that. Also don't know that there is a line going down on the day/night shades but I'll check on that too.
2017 Columbus 320RS
Old 06-01-2016, 01:32 PM   #5
Elkhounds's Avatar
Well just to update. I took the valence off and with the day/night shades there are 2 shades rolled up. When we got home from the last trip the day shade was all the way down. Rolled it up using the gear like piece on the left not the right side. Once rolled up it is like that recharged the spring inside. Seems to go up and down now better than it did before.
So we will see how it goes in our upcoming 5000 mile trip in June. Hope we have no more issues.
2017 Columbus 320RS
Old 06-30-2016, 11:36 PM   #6
Charles.maine's Avatar
Does anyone else have shades that only go down over 1/2 the window? My large dining room window when I pull both the day and night shades down they leave about 6 inches of the window exposed. I thought maybe they were out of adjustment but nope there is actually no shade left on the roller. Any thoughts???
2015 Chevrolet Silverado 2500HD 4x4 Z71 Duramax/Allison Combo Pull Rite, ISR Series Superglide 16K, LoadLifter 5000 Ultimate W/ WirelessOne
Current RV: 2016 Palomino Columbus 381FL Fifth Wheel
Lippert Flex Air Pin Box, LT235-85-16 GY G614
Nights Camped 2013 - 6 • 2014 - 7 • 2015 - 12 • 2016 - 29 • 2017 - 16 (17 more planned!!)
Charles.maine is offline   Reply With Quote
Old 07-01-2016, 11:26 AM   #7
Elkhounds's Avatar
We were told to only use one and not both. So if we want the night shade we run up the day shade first. Not sure if that would be an issue for you or not. All our shades reach all the way down. Hope you get it figured out.
2017 Columbus 320RS
Old 07-01-2016, 01:45 PM   #8
Doesn't seem to make and difference whether just one shade or both are down.
ID:	112764   Click image for larger version
Old 07-01-2016, 01:47 PM   #9
This is them pulled all the way down.
Old 07-05-2016, 03:09 PM   #10
Elkhounds's Avatar
Sorry for not seeing this before now. Quite the bummer. Not sure if you can take the valence off and see if there is more material on the roller or not. Maybe they just messed up and put one on that window that was designed for a shorter window. Either way I would be talking to the dealer about it. If they can't help contact Columbus directly. Good luck with it.
2017 Columbus 320RS
Old 10-07-2017, 12:29 PM   #11
We have a 2017 383FB Columbus and most of our shades don't work well. I found instructions on how to adjust the shades in the packet of information that has the water heater, refrigerator and other manuals. The hardest part on ours is getting the valances off. As you can see they are attached with small L brackets that are hard to reach. I had to buy a long shaft (8 or 9 inch) Phillips to be able to reach the screws. I got one off and tried to adjust the shades. Didn't go well so I quit. Our trailer is going back to the factory early next year so we are going to live with the shades until then. Cheap shades but we like them better than the accordion style we had in our last trailer. Good luck.
condojj48 is offline   Reply With Quote
Old 10-07-2017, 12:50 PM   #12
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
We have both day and night down frequently and ours work great.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 121
rjshiflet is offline   Reply With Quote
Old 10-07-2017, 02:30 PM   #13
Great!!
Old 10-13-2017, 10:54 AM   #14
Elkhounds's Avatar
I'll admit I gave up on this. We have found that if we help them up the go up far enough for us to deal with. I'll have to see if I can use a long phillips to get to the screws like you did and give it a shot. Just put the trailer to sleep for the winter on Monday. Sad day but won't be getting it back out now until spring.
2017 Columbus 320RS
Old 11-04-2017, 07:25 PM   #15
I have the same problem, but my shades will not retract completely, hanging down about 4 inches. The real question is how to remove the valance? I have instructions on how to adjust the roller.
John & Carol
2017 Columbus 383FB
1999 F550 7.3
Livingston, Texas
Cane Raiser is offline   Reply With Quote
Old 11-22-2017, 03:43 PM   #16
Elkhounds's Avatar
I think removing the valance involved a short screw driver IF I remember correctly. I won't be able to get back to it until spring.
Can you post or PM me the instructions for adjusting the rollers?
2017 Columbus 320RS
columbus
