Old 10-11-2013, 07:34 AM   #1
Don and Elaine's Avatar
Columbus thermostat issues
Our Demotic thermostat is very complicated to use and sometimes does not know the difference between heat and air conditioner. Last night my wife went to turn the heat down and behold....the AC came on! On our previous TT, a Flagstaff, I was able to swap out the cheap Duo Therm thermostat for a Hunter digital thermostat that was easy to operate and worked like a charm. We only have a single A/C unit so we only need a single zone thernostat. Is there another thermostat that could replace the current Dometic and had anyone else had operation issues?
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 50 days in 2015, 74 days in 2016, 92 days in 2017, and 94 days in 2018.
Don and Elaine is offline   Reply With Quote
Old 10-11-2013, 08:58 AM   #2
iceblaze580's Avatar
On the t-stat set fan speed to auto that will fix it
iceblaze580 is offline   Reply With Quote
Old 10-11-2013, 01:41 PM   #3
treaves's Avatar
It's really very easy to use, and works well. You just need to read the instructions, and the thermostat as well. If it went from heat to ac, you have it in the auto mode, instead of either heat or ac.
2012 Ram 2500 Laramie Limited CCLB CTD
2014 Columbus 320RS
treaves is offline   Reply With Quote
Old 10-11-2013, 03:19 PM   #4
jtstromsburg's Avatar
This, but fan to auto, not low or high
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
columbus, thermostat
