Old 05-04-2012, 06:08 AM   #1
ret2006's Avatar
Converter problem
Anyone had problems with their converter? I am on a 10 day trip and mid week noticed my battery was not fully charged (I am connected to shore power). When checking with a meter it only showed 12.11 volts and should be 12.70 min. All fuses in the electrical panel were OK. I had to pull out the entire fuse panel to get to the converter. The two fuses were OK, the converter was warm to the touch which seemed to be normal. Fan was not running. It just isn't charging the battery. Nearest dealer over 40 miles away so I opted to go to Wal-Mart and get a small battery charger (I only had four battery chargers at home, now I will have four at home and one in the camper) as to not let the new battery run down too much. This will get me by until I can get it by my dealer for repair.
I did call my dealer and they promptly found the nearest dealer to me, that dealer service department called me but I opted to not pull up camp and spend a day, I had rather have my local dealer take care of it. My dealer is only 20 minutes from my house.
I may opt to add a few bucks and get a better converter.
Any comments?
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 05-04-2012, 06:52 AM   #2
TURBS's Avatar
Request a progressive dynamics
Old 05-04-2012, 06:54 AM   #3
TURBS's Avatar
Assuming u have a wfco herk has a testing guide
Old 05-04-2012, 07:05 AM   #4
We had the exact same symptoms a few years a go on our previous TT. The only difference was we noticed it on our last day so I skipped the "buy a charger at Walmart" step...
...It did turned out to be a bad inverter board. It was quickly replaced and we never had another problem with it for the 9 years prior to trading it in on our Sabre..
Cathy & Jeff
Midland, Michigan
2020 Cedar Creek 34IK / 2019 Ram3500 CID
SimchaSabre is offline   Reply With Quote
Old 05-04-2012, 07:18 AM   #5
Herk7769's Avatar
The reason the troubleshooting guide requires you to remove the battery from the camper to check the converter's output voltage is that a dead cell in the battery can show the very same symptom as a bad inverter board; low voltage.
HAM CALLSIGN - KC3FFW
Old 05-04-2012, 07:29 AM   #6
TURBS's Avatar
When my wfco converter went bad the reason it went out was the fan.
The fan would get hot and quit working then the converter would overheat.
When the converter overheated it would stop charging.
When everything cooled down again the process started all over again.
that's when I switched the converter out for a progressive dynamics.
Never had an issue again.
My wfco was a 55amp I replaced with a pd 70 amp.
Old 05-05-2012, 05:17 AM   #7
ret2006's Avatar
Sounds like that is what is happening to my converter. I thought I could hear the fan kick on again.
Old 05-12-2012, 04:31 PM   #8
website for progressive dynamics????
mark239 is offline   Reply With Quote
Old 05-12-2012, 04:53 PM   #9
Triguy's Avatar
progressivedyn.com
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-12-2012, 09:37 PM   #10
Old 05-12-2012, 09:44 PM   #11
TURBS's Avatar
A pd charger will fit into a wfco unit with a little bit of modification .
I have done it a few years ago.
Another poster just recently took my advice and did the same.
Old 05-12-2012, 09:48 PM   #12
Mine started causing problems last fall fan not running correctly
Old 05-12-2012, 10:01 PM   #13
TURBS's Avatar
Weak link in a wfco convertor is the fan.
The other thing I have done is put a computer fan in the cupboard my convertor is mounted in to help with air flow .
