Old 02-21-2013, 10:47 PM   #1
Mike Zeto
Cream colored Silicone caulk for Columbus
Does anyone know where you can get the cream colored silicone caulk for the columbus.
mzetp is offline   Reply With Quote
Old 02-22-2013, 07:38 AM   #2
Trailer Trash
It's a TPO roof by Alpha Systems. Start here:
Alpha Systems, LLC - Products for the RV, Cargo Trailer, Marine and Modular & Manufactured Housing Industries
I'm sure they used something other than just plain ol silicolne caulk. However TPO material for RV roof is common now. I would stop at a camping world store and have a chat with them. Also go to your favorite RV dealer and ask them also what they use in their repair bays.
joelek is offline   Reply With Quote
Old 02-22-2013, 02:20 PM   #3
Factory Rep
Just to Clarify. Columbus puts the rubber roof on , not TPO.
Chris
Christopher Columbus is offline   Reply With Quote
Old 02-22-2013, 05:38 PM   #4
Mike Zeto
I need to do some touch up on my 320 and need to know what type, brand and color Columbus uses. I have the brown and cream color trailer.
Thanks Mike
Old 02-22-2013, 08:16 PM   #5
Trailer Trash
Chris
Thanks for update CC. I will adjust my info file.
You may want to send that info out to dealers. I bet you more than mine has it listed wrong. Mine was cheyenne camping center - Iowa.
Old 02-22-2013, 08:23 PM   #6
Earth Station's Avatar
We have rubber roof???? I thought we had the new RV type roof!!!
Felicia & Jeff - Missouri
2013 Columbus - 320 RS 2012 F350 CC DRW - 6.7L PSD
2012 Camping 59 DAYS; 2013 50 DAYS; 2014 WAITING
Earth Station is offline   Reply With Quote
Old 02-22-2013, 08:31 PM   #7
Trailer Trash
It's winter in the snowbelt but for you lucky guys in the south, here is how to confirm what you have for roof material.
RV 101 – How to Determine RV Roof Types | The #1 RV Video Education training Source RV 101
TPO Thermoplastic Polyolefin or
EPDM ethylene propylene diene monomer rubber
TPO is newer style but I don't know what the advantage is. We assume newer is better but that may not be the case for RV roofing.
I would think Dicor brand would have a roof sealer product in cream color but who knows.
Old 02-22-2013, 10:21 PM   #8
Try Amazon.com. They have several colors.
Amazon.com: dicor lap sealant
l001952119 is offline   Reply With Quote
Old 02-23-2013, 02:34 AM   #9
SYE
SYE's Avatar
My Columbus has a Gray roof on it and when I added my Fantastic Fan vent cover all I could find is the white lap sealant. I called Dicor direct about getting the Gray caulk and they told me that I could order it by the case and it was like 175.00 for the 12 tubes. So I just used the white that I had because it would dry up by time I used that much of it. No one can see it on top of the roof anyways.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 02-23-2013, 08:40 AM   #10
Trailer Trash
I made a pdf quick cheat sheet so you can inspect your own room and find out if you have a TPO or EPDM style room material. You need to know this for picking sealer, cleaner, patches, repair kits, etc. for your particular type of roof. The color on the back is the telltale key.
Black on the back = EPDM
White (same color top bottom) on the back = TPO.
Old 02-24-2013, 08:10 AM   #11
I also need some cream color sealant for the sides of my 320rs. Not for roof seams which are of course white. This would be for seams and down spout areas. It sure appears to be silicone caulk. Has anyone looked for this from any vendors? Thanks
mmunn is offline   Reply With Quote
Old 02-24-2013, 08:28 AM   #12
SYE
SYE's Avatar
When I called Dicor about the gray sealant, they told me the caulk was the same item as the roof lap sealant, I found that hard to believe
Scott & Vicki
Old 02-24-2013, 09:22 AM   #13
Why not just apply a clear RV specific caulking over the area? Proflex (one of the highest rated) comes in clear. Proflex is available at Campingworld and many other RV stores - it is specifically made for RV applications where there is flex and movement.
ProFlex RV Flexible Sealant - Clear - Geocel Corp 28100 - Roof Maintenance & Repair - Camping World
It is also available in Almond, but I don't know if that's the same as champagne:
ProFlex RV Flexible Sealant - Almond - Geocel Corp 28109 - Roof Maintenance & Repair - Camping World
Also, unless the manufacturer is using silicone DO NOT use it to seal the unit - it is impossible to seal over silicone after it is applied unless cleaned with a cemical cleaner like acetone or mineral spirits.
mwebber78 is offline   Reply With Quote
