Old 10-16-2012, 11:46 AM   #11
Originally Posted by hd riders View Post
Hi All
Went with the 18K superglide for peace of mind. For anyone with the superglide you do not use a lube disk what do you use if anything??
I don't think that a lube disk with fit my SG. I just lube everything (plate, rails, etc) with WD40.
bjlowe is offline   Reply With Quote
Old 10-16-2012, 11:46 AM   #12
1jeb289's Avatar
No need for a lube disk as the capture plate on the pin box does not turn on the hitch plate. Just be sure to keep the way tubes sprayed with WD-40. I spray mine down before hook up and the spray WD-40 every time we stop. No problems. I have been in a couple of situations in state parks where the Pullrite saved my rear truck window and corner of the camper from making the kind of contact that you do not want.
1jeb289 is offline   Reply With Quote
Old 10-16-2012, 12:15 PM   #13
Herk7769's Avatar
Hi All
As said before; no lube disk needed since the pin does not pivot in the latch. The entire hitch head rotates on the hitch body as designed.
HAM CALLSIGN - KC3FFW
Old 10-16-2012, 12:16 PM   #14
Camper Less Camping
Cajun Po-Boy's Avatar
X2...just use WD40 as recommended in manual
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-16-2012, 12:50 PM   #15
hd riders's Avatar
Thanks All
Going to have hitch installed in a couple of weeks just before our 320RS gets to dealer.
hd riders is offline   Reply With Quote
Old 10-18-2012, 09:28 PM   #16
Who has a super glide hitch and a 320RS with a 6 1/2 ' bed? Do you have any limitations with turning? Will it turn 90 degrees?
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
Old 10-19-2012, 06:27 AM   #17
CheezPack's Avatar
We have a Sabre 34RLQS with a 6 1/2' bed and absolutely no limitations! Think we might have exceeded the 90 degrees a couple of times LOL.
2013 Sabre 34 RLQS
2010 Ford F250 diesel
FRF & FROG member
Rallies 12 & 13, Cherry Blossom 13, Branson 13... More to come!
CheezPack is offline   Reply With Quote
Old 10-19-2012, 08:16 AM   #18
Camper Less Camping
We have the Sabre 32RCTS-6 (Palomino Brand as the 320RS), no problems going 90 with our SB & Pullrite hitch.
Old 10-19-2012, 09:24 AM   #19
1jeb289's Avatar
We have the 320RS with the Pullrite and 6.5 bed. Have not had a problem making a 90 degree turn.
Old 10-19-2012, 02:41 PM   #20
Limitations / Yes. 90* No, per Kyle at Salem RV. This was my concern also and Kyle had a friend with 6-3/4' SB Ford with a slider hook up to the 320RS that I'm buying.
In the parking lot they could pull a comfortable 75* to 80* turn. They are installing a Pullrite 16K slider next Wed and will be picking up the trailer on Friday. Testing will be done in the lot with my set-up at that time.
Doug
Pa-cj5 is offline   Reply With Quote
