Old 10-04-2012, 01:52 PM   #1
hd riders's Avatar
Curt 20K Slider or 18K Pullrite Sugerglide
Is the Pullrite that much better than the Curt for the money difference????
Going to be pulling a 320RS
hd riders is offline   Reply With Quote
Old 10-04-2012, 03:08 PM   #2
Camper Less Camping
Cajun Po-Boy's Avatar
It all depends on what you want out of your hitch to determine if the additional expense was worth it.
For me, I was looking for the following features:
*automatic-don't want to think about every turn whether I can make it or not
*simple-don't want to go through the "dance" when needing to activate the slide
*convenience-if I got in a situation while it's raining, didn't want to deal with the manual slider
*tight tolerances-didn't want to hear the manual slider noise during towing due to the design and many parts of the manual slider
Overall, it's a fit for me and like most SB truck owners, probably won't need the slider much but nice to know it's there and AUTOMATIC
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-04-2012, 03:28 PM   #3
Herk7769's Avatar
If you are looking for "Voted with my wallet"
The Superglide is my first and only choice.
HAM CALLSIGN - KC3FFW
Old 10-04-2012, 05:23 PM   #4
slide5r4fun's Avatar
We chose the Pullrite 16K Superglide. Like Ragin Cajun listed above, not sure if we will ever use the slide function but we know we didn't want to worry about it. We also went with the Super Rails which are totally removable from the bed of the truck when not in use. Although it cost more for the Super Rails, we wanted to have an empty bed when not towing. It's not a lightweight task to remove the hitch and rails. I can get the hitch out and to the edge of the tailgate and my wife and I can handle lifting it out of the truck. Total time to install or remove hitch is 5 minutes.
Kevin & Janine
2019 F350 Lariat DRW
2020 Jayco Pinnacle 36KPTS
slide5r4fun is offline   Reply With Quote
Old 10-04-2012, 05:47 PM   #5
Herk7769's Avatar
I am alone when I need to get the hitch out.
So I use the kingpin and camper as a crane.
I keep the camper hitched and lift the weight off the hitch with the landing gear.
(just about 1/4 inch of air above the plate)
Then I pull the pins connecting the hitch body to the rails.
Using the landing gear I raise the hitch and (using a pry bar) wiggle the hitch clear of the rails.
Then I raise it completely up, clearing the rails and drive out from under the hitch. I re-level the camper (leaving the hitch on the kingpin).
When I winterize the camper; the hitch is lubricated and bagged in plastic.
The rails are stored in the garage. I bought 4 Ford F-250 bumper plugs and they fit perfectly into the holes in the bed (locking into the Superglide body mounts).
Old 10-04-2012, 06:04 PM   #6
Now a "Top Member"
EdJunior's Avatar
I have the Curt Q20 slider, and have never really had a need to use it yet. For me, the money saved is well worth it for the number of times I've used the slider (0). Well, I have used it, but I didn't "NEED" to use it. Just wanted to make sure it still worked.
Ed and Sharon
2010 Wildcat 28RKBS
2019 Ford F-250 XLT - AWESOME Truck!
Old 10-04-2012, 06:12 PM   #7
That's a nifty process you use Herk. We have to store our trailer off site so I would not be comfortable leaving my hitch on the rig, otherwise I would switch to your system on the next camping trip. Sounds very easy and pratical. The hitch dealer mentioned the Ford bumper plugs will fit the holes in the bed but I didn;t check into that. Thanks to your post, I'll be getting those soon.
Kevin & Janine
Old 10-16-2012, 10:25 AM   #8
Ragin Cajun hit the nail on the head. Similar to Lou, I voted with my wallet too.
18K Superglide
bjlowe is offline   Reply With Quote
Old 10-16-2012, 11:05 AM   #9
I have to vote for the Pullrite hitch. Pullrite has a video on utube comparing the difference in design that convinced me. It maybe a little exaggerated, but if your favorite RV spot is on a grade and the drive is narrow, found in many public parks, you'll learn the extra money was well spent. I found a used one on Craigslist and save a lot of money. You may have to buy a universal rail kit to fit your truck.
cruisinhwy66 is offline   Reply With Quote
Old 10-16-2012, 11:30 AM   #10
hd riders's Avatar
Hi All
Went with the 18K superglide for peace of mind. For anyone with the superglide you do not use a lube disk what do you use if anything??
Old 10-16-2012, 11:46 AM   #11
Originally Posted by hd riders View Post
Hi All
I don't think that a lube disk with fit my SG. I just lube everything (plate, rails, etc) with WD40.
Old 10-16-2012, 11:46 AM   #12
1jeb289's Avatar
No need for a lube disk as the capture plate on the pin box does not turn on the hitch plate. Just be sure to keep the way tubes sprayed with WD-40. I spray mine down before hook up and the spray WD-40 every time we stop. No problems. I have been in a couple of situations in state parks where the Pullrite saved my rear truck window and corner of the camper from making the kind of contact that you do not want.
1jeb289 is offline   Reply With Quote
Old 10-16-2012, 12:15 PM   #13
Herk7769's Avatar
Hi All
As said before; no lube disk needed since the pin does not pivot in the latch. The entire hitch head rotates on the hitch body as designed.
Old 10-16-2012, 12:16 PM   #14
Camper Less Camping
X2...just use WD40 as recommended in manual
Old 10-16-2012, 12:50 PM   #15
hd riders's Avatar
Thanks All
Going to have hitch installed in a couple of weeks just before our 320RS gets to dealer.
Old 10-18-2012, 09:28 PM   #16
Who has a super glide hitch and a 320RS with a 6 1/2 ' bed? Do you have any limitations with turning? Will it turn 90 degrees?
Dave and Kim
Charlie and Ripken (4 Leggers)
2012 GMC Sierra Denali 2500 6.6L Diesel
2013 Columbus 320RS
Maryland
Times camping in 2013 - 5
Sporoo is offline   Reply With Quote
Old 10-19-2012, 06:27 AM   #17
CheezPack's Avatar
We have a Sabre 34RLQS with a 6 1/2' bed and absolutely no limitations! Think we might have exceeded the 90 degrees a couple of times LOL.
2013 Sabre 34 RLQS
2010 Ford F250 diesel
FRF & FROG member
Rallies 12 & 13, Cherry Blossom 13, Branson 13... More to come!
CheezPack is offline   Reply With Quote
Old 10-19-2012, 08:16 AM   #18
Camper Less Camping
We have the Sabre 32RCTS-6 (Palomino Brand as the 320RS), no problems going 90 with our SB & Pullrite hitch.
Old 10-19-2012, 09:24 AM   #19
1jeb289's Avatar
We have the 320RS with the Pullrite and 6.5 bed. Have not had a problem making a 90 degree turn.
Old 10-19-2012, 02:41 PM   #20
Limitations / Yes. 90* No, per Kyle at Salem RV. This was my concern also and Kyle had a friend with 6-3/4' SB Ford with a slider hook up to the 320RS that I'm buying.
In the parking lot they could pull a comfortable 75* to 80* turn. They are installing a Pullrite 16K slider next Wed and will be picking up the trailer on Friday. Testing will be done in the lot with my set-up at that time.
Doug
Pa-cj5 is offline   Reply With Quote
