Old 08-21-2016, 04:06 PM   #1
mikejm
Dining slide out screams when it is going out and coming in. Have lubed both teeth arm
Columbus by Palomino 320 RS
mikejm is offline   Reply With Quote
Old 08-22-2016, 10:01 AM   #2
Head Rambler
Did you lube the sliding rail all over? If not try lubing the entire sliding mechanism.
You may need to run it in and out a few times, lubing it each time before you get it to stop yelling at you.
Gotta go campin!
Old 08-22-2016, 10:05 AM   #3
Yes, you will need to lube more than just the teeth.
Also use a good DRY lube. Do not use spray grease.
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 08-22-2016, 01:14 PM   #4
mikejm
Did not lube entire arms, just the teeth. Will try lubing entire arms.
mikejm
Old 08-24-2016, 08:23 PM   #5
Is it a Schwintek? If so, go to their website. They have troubleshooting instructions and lubrication procedures, complete with videos.
campingguy is offline   Reply With Quote
Old 08-25-2016, 12:08 AM   #6
mikejm
camping guy I don't know what a Schwintek is. mikejm
Old 09-06-2016, 02:20 AM   #7
This is a schwintek:
bed, slide, slide out
