Old 09-14-2013, 05:33 PM   #1
Direct tv wiring issue
Direct tv tv here now. Cannot get get signal inside camper?
Tsan731 is offline   Reply With Quote
Old 09-14-2013, 05:36 PM   #2
We cannot get a signal on the living room tv. Satelitte jacks within camper not working? Any advice?
Old 09-14-2013, 06:38 PM   #3
Jimmerinwi's Avatar
Is the booster on the wall plate off? If you run a direct line to the receiver without going through the camper lines, does it work? You may have to trace the lines to find a direct sat feed line in the camper. If the Direct guy has a "toner" he should be able to find it.
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 09-14-2013, 07:54 PM   #4
If you've never used the Cable-In on your RV, my guess is that they swapped the Sat & Cable input wires. It might also help if you told us what brand and floorplan your RV is, either in your Signature or Profile information.
Old 09-15-2013, 08:03 PM   #5
Sorry for the lack of info. We have a Columbus 365 rl, we were able to get the the direct tv working in the basement area but not the living room. Direct tv tech said that it was a wiring issue in the camper but we have not had a chance to check it out yet.
Old 09-16-2013, 10:54 PM   #6
iceblaze580's Avatar
I took my 325 in for the same issue the signal splitter behind the wall in the basement was bad
iceblaze580 is offline   Reply With Quote
Old 09-17-2013, 05:13 AM   #7
ret2006's Avatar
Satellite has to have a direct cable with no splitters between. If you are getting a connection to the basement outlet, sounds like it is wired wrong. Usually bedroom and basement cable outlets are fed through a splitter behind the booster which would give you cable TV and OTA antenna signal to bedroom and basement. I have found two of the four fifth wheel trailers I have owned in the past six years, all different manufactures, there was a problem with the cable wiring. One I never did get any signal to the bedroom, had to run a cable through the window. I think most all RV manufactures must hire 5 year old's to do the television cable wiring.
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
wiring
