Old 10-10-2012, 12:00 PM   #11
J_KHawthorne's Avatar
I would certainly recommend a slider!!! The Pull Rite is a great hitch, and my Reese 16K slider is good also.
The issue is more than just at the corners of your truck cab: a slider will also provide you with more clearance over the rear top 'corners' of your truck box for those times when you're on the up&down bumps you sometimes encounter going into or out of some of the more rustic camps and parks.
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
