Old 01-24-2014, 11:24 PM   #11
Oklahoma Proud
MillerTime's Avatar
I haven't seen a yellow sticker on one (36 qbok) yet that was below 11,800ish. Most were around 12,400- 12,800. Look around on the web. Some dealers show the yellow sticker, but ive also seen several in person, and they didn't have all the options that I wanted either.
-most of the numbers will say don't, to towing with a 3/4ton, but its up to you to make the call.
oops. forgot to check mark that stupid box again!
Old 01-24-2014, 11:47 PM   #12
SYE
SYE's Avatar
f1100 Turbo does but I think his is a 32qbok!! He has a 2500HD with the 6.6 Duramax
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 01-25-2014, 06:12 AM   #13
Pirates55's Avatar
The yellow sticker on the 36qbok at the show today was 12,481.
Pirates55 is offline   Reply With Quote
Old 01-26-2014, 08:10 AM   #14
I pull a 33ckts-6 with a 06 dodge 2500 with no problems.
bignugget is offline   Reply With Quote
Old 01-26-2014, 06:50 PM   #15
QCCowboy's Avatar
I pull mine with an F350 DRW and myself would advise against it, however you'll hear a lot of people say that it can be done and it really depends what you are comfortable with. I've seen a 36QBOK pulled with an F250 with the 6.7 in it (and to top it off both the truck and the camper had 6" lifts on them.)
Jack of all trades - Master of none
2012 F350 CC DRW - 6.7L PSD
2014 Sabre 36QBOK
QCCowboy is offline   Reply With Quote
Old 02-01-2014, 07:04 AM   #16
speedcat's Avatar
I tow with a 2004 Chevy Silverado 2500 HD with 8.1l gasser. Dry weight 12488. Have not had any problems but most of my trips are flat land. I have pulled some long grades with no problems. The firestone air bags made a big difference and the unit is balanced very well. When I go to full timing it will be in a 1ton.
2018 Heartland Landmark 365 Charleston
2008 Ford F350 King Ranch CC DRW 6.4l, 4.10 diff
B&W companion
Airlift system/on board compressor
speedcat is offline   Reply With Quote
Old 02-01-2014, 09:10 AM   #17
Pirates55's Avatar
Does anyone tow the Sabre 36qbok with a 3/4 ton diesel
I'm going to tow mine with a SRW F-350. 4 door Short bed FX4 diesel. I did install the pullrite superglide 16K hitch.
Old 02-01-2014, 09:38 AM   #18
speedcat's Avatar
I don't think you will go wrong with that TV. I vasilate between SRW and DRW. I think my next fiver will be heavier so I lean toward the DRW for stability and added safety in case of a tire blowout.
B&W companion
Old 02-01-2014, 12:37 PM   #19
Camper Less Camping
Cajun Po-Boy's Avatar
IMO...If you are a weekend warrior, you'll be fine...still over weight, but your truck will handle it flawlessly.
If you were going to be most timing or full timing, I'd move up in truck to accommodate the larger 5'ver...Have fun in your search!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 02-01-2014, 12:43 PM   #20
Pirates55's Avatar
Don't understand the overweight. Trucks rated to pull a fifth wheel 15,400lbs. Loaded I expect my trailer to about 13,000 lbs. we never carry water in our tanks. DRW truck only goes up to 15,600lbs in the 4x4 model. See attached chart below
diesel, sabre
