Old 09-06-2016, 08:16 AM   #1
Dometic thermostat
This weekend while camping both of my ac units turned off. At first I thought the park lost power but the power was still on, turned out the thermostat was indicating an E1 error message. I would think since both ac's went off that its the thermostat. Anyone else have this issue?
Kstedman is offline   Reply With Quote
Old 09-06-2016, 08:19 AM   #2
Mr. Dan's Avatar
What kind of trailer do you have?
My Wildcat has 2 A/C units - but it also has 2 thermostats.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 09-06-2016, 08:39 AM   #3
Its a Columbus 340RKC with dual ac's and a single CCC2 thermostat.
Old 09-06-2016, 03:02 PM   #4
Head Rambler
E1 is a communication error. While it's likely the thermostat, it could also be one of the control boards disrupting the communications on the network.
Did you try reinitializing the thermostat?
Unfortunately there have been a good many issues with these digital thermostats.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-06-2016, 03:07 PM   #5
Mr. Dan's Avatar
Sorry, Kstedman. I went silent since this is out of my league!!
Old 09-06-2016, 08:19 PM   #6
I have the same FW and the thermostat is a pain. When I had troubles with it, and it has been more than once, I rebooted following the instructions in the manual. I wish it would come with two thermostats.
2017 Leprechaun 311 FS
Jeep Patriot and Cherokee as toad.
Enjoying retirement.
jonwisconsin is offline   Reply With Quote
Old 09-10-2016, 09:44 PM   #7
CWG
The front AC in my 340 RKC will not turn off without shutting down the breaker. Obviously FR are have issues with this set up.
2017 Columbus Compass 340RKC
2003 GMC Seirra 2500HD 4x4 Duramax
CWG is offline   Reply With Quote
Old 09-11-2016, 08:37 AM   #8
Head Rambler
It's actually not FR's problem, though they have some culpability because they install the units. It's Dometic's problem.
There have been a few reports of the A/C units with the digital thermostat not shutting down. If I remember it's been the control board in most all the cases.
Just for fun, have you tried initializing the thermostat to see if that helped?
Gotta go campin!
Old 09-11-2016, 11:11 PM   #9
CWG
Yes sir Bama Rambler, I did give it a try to initialize the theromastat with no luck. Thank you for the suggestion.
Old 09-12-2016, 05:53 AM   #10
Head Rambler
I didn't think it'd work, but it was worth a try.
Hopefully it's under warranty, but even if it isn't I'd contact Dometic and see what they'll do for you.
Gotta go campin!
dometic, thermostat
