Old 09-02-2013, 05:50 PM   #1
Dometic toilet model 310
We have a fifth wheel Sabre 32BHOK with a Dometic toilet model 310. We are going to replace it with something else because of the problems we have had. Any suggestions on what to buy?
bulldog203 is offline   Reply With Quote
Old 09-03-2013, 06:52 AM   #2
KyDan's Avatar
There is a possible solution in another thread
here--> Toilet Install Precaution
(READ POST #1 there please)
Bulldog are you sure you want another toilet or is your problem more
of a bad/leaking seal at the floor flange???
This is a valid question!
Can't help you with a replacement as I have no experience there.
Good luck with your quest for a better potty! This is one subject that
comes up a LOT in the forums. Seems like the manufacturers could come
up with better solutions but RVs are a unique situation. Unless you have
a full time site with full time sewer hookups and unlimited water you don't
have much choice in toilets. They are all similar as far as I can tell.
Take a look at this one--
Good Luck!!
Dan & Rita D
2004 5.3L Silverado 1500 ext. cab 2WD
Blue Ox WD hitch, AirLift load levelers
2013-41, 2014-31, 2015-40, 2016-38
Old 09-03-2013, 10:13 AM   #3
Angela, a little birdy told me that you may have been able to fix your issue and you will see how it works out. I'm impressed- when faced with toilet issues + replacing it, I opted for Dometic to send my new toilet to a RV Service Center.
Though, I did end up arm-deep in a toilet around July 4th dealing with a clog!
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
