12-06-2017, 09:42 AM
Drying her out
So, if you pull the plug to empty the water heater, empty the filter reservoir, dump the tanks and open the low drain points, does that dry the Columbus up? What else might there be? I read the winterizing stuff and from memory, I think that covers it, aside from adding anti-freeze, which I am not doing. Just trying to mitigate freezing risk and will look those instructions up again.
I will have the heater will be on as it gets pretty cold this weekend but again, let's get the water out of it.
2017 Columbus Palomino F366RL
2016 GMC Duramax 2500 HD, PPEI Tuned, B&W Hitch
12-06-2017, 09:47 AM
Draining as you've mentioned does not address any water in the water pump.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=64
12-06-2017, 10:15 AM
Ok, that's valid.
12-06-2017, 10:27 AM
It also doesn't empty the traps in the drains. I know you said that you'll have the heater on, but what if the heat fails? I think I'd dump a little anti-freeze in the traps just for insurance.
Gotta go campin!
12-06-2017, 10:38 AM
Draining as you mentioned won't always get the water out of the toilet valve.......... nor the outside shower... may not drain the inside shower hose, either.
12-06-2017, 10:46 AM
Without pumping air or anti-freeze, it doesn't clear all the water from the lines.
12-06-2017, 11:26 AM
There are usually several low spots in the plumbing and they will not be drained bu opening the low point drains. At a minimum you need to blow the lines well. The extra hour and $10 to add antifreeze is certainly much better and less expensive than a plumbing repair in the spring.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
12-08-2017, 08:56 AM
There are no traps in a Columbus, they use trap-less drains. To be on the safe side, I would still blow out the entire water system including the toilet and bidet hose and still pink juice the system for piece of mind and also to winterize the pump.
2016 Dodge Ram Dually 4X4 Quad cab LB 3500 Cummins 6.7L TD / 2013 Columbus 320rs. Camped 92 days in 2017, 94 days in 2018, 108 days in 2019 and 112 days in 2020.
12-08-2017, 08:59 AM
Insert witty title here
Then how do they keep tank stink out of the cabin?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
12-08-2017, 12:45 PM
They have these, Hepvo Waterless Drains.
Gotta go campin!
12-08-2017, 01:10 PM
Scoundrel
If you're determined to not doing the antifreeze part I would minimally blow the lines out, then pull the valve off the back of the toilet.
2024 Geo Pro 15TB, 400W Solar, 2 Golf Cart batteries
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller, Roadmaster Active Suspension
Wooden Spoon Survivor
12-09-2017, 11:08 AM
Pull the water pump too.
12-09-2017, 11:51 AM
Advice on toilet valve is good.
The one cold snap my rig was not in Florida yet, I just blew out the lines and walked away happy.....until I hooked up again. The toilet valve will leak quickly and badly. All else was fine. That valve is not cheap either.
Travel safe
2019 Ford F-350 Super Duty CC Dually 6.7 Diesel
2011 Cedar Creek 36CKTS Touring Edition
I Catch Fish......What is your SuperPower?
12-10-2017, 09:20 AM
My unit does not sit until spring. It goes out every couple weeks so I would spend the same on propane of AF every couple weeks. It's certainly not the $, it's dealing the constant pink stuff. I'll just keep her on warm.
12-10-2017, 09:55 AM
Travel safe
I never use the pink stuff in my water lines, just blow them out. The toilet valve is the only place I've ever had trouble. It never occurred to me to unhook it, think I'll start doing that.
2015 Ram 3500 CC SRW SB 6.7 Cummins
2015 Sabre 36QBOK-7
Nights Camped, 2015: 23, 2016: 27, 2017: 29, 2018: 22, 2019: 29
12-10-2017, 09:57 AM
Warm up the Black tank flush nozzle area and the pre filter in front of your water pump and make sure your shower valve outlet is facing the Down position and make sure your plumbing lines have no Dip/Low spots in a location where a Plastic fitting is located,these will also bust! Most just use A/F and sleep well on a COLD night others Worry about Next Spring! Youroo!!
12-10-2017, 09:59 AM
I sleep well knowing my water lines aren't being marinated with antifreeze.
2015 Sabre 36QBOK-7
12-12-2017, 06:07 AM
What type of water lines do you have that allow "Marinating/Leaching"? Do you also throw away "Tupperware" after 1 use? Youroo!!
12-12-2017, 06:28 AM
"On the road again"
We take ours out every month for at least 8 to 10 days/nights on the road, so the hassle of flushing pink stuff each month has never appealed to me. And, we don't have that much really cold weather here in North Texas.
I've lost the expensive toilet valves twice...lesson learned.
Otherwise, I do blow out the lines if a freeze is coming and this past week when the temperature dropped into the teens I kept the furnace going inside set at 44 degrees as well as the tank heaters after I blew out the lines...including opening the toilet valve and blowing it out and the outside shower.
That's always worked for me - hopefully it will continue to work fine.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
12-12-2017, 08:19 AM
You get more chemicals from an insulated Hot/Cold beverage container than you'll get from RV antifreeze.
