Old 07-16-2019, 11:44 AM   #1
Ovi
DSI
I have a Solaire 240bhs. When I turn on my hot water a DSI fault light comes on. The water still heats up but does this mean I am working only off propane and not the shore power I am hooked up to? Any thoughts?
Ovi is offline   Reply With Quote
Old 07-16-2019, 12:04 PM   #2
llr
DSI would mean the propane is not working, could be a lot of possibility's
Do you have propane? Is it turned on?
Have you purged the lines? Running the stove will help but it still could take a number of cycles to get the air out.
Spider webs in the gas tube.
Turn it off, then have someone turn it one while you are at the WH.
Do you smell gas?
Do you hear and see a spark?
TT 2017 Flagstaff 831CLBSS Classic Ultra lite
TV 2014 Silverado 2500 HD
llr is offline   Reply With Quote
Old 07-16-2019, 12:26 PM   #3
Just as confused as you
Scrapper's Avatar
Check the ECO/High Limit reset on the wh behind the outside panel. If your wh is both LP and electric there will be 2 of them, one for electric and one for LP.
What is the make and model number of your wh?
Name:	Element & Resets.jpg
ID:	210042   Click image for larger version
Name:	High Limit Resets.png
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 07-16-2019, 12:46 PM   #4
Does it come on the very first time after you turn on the propane or after subsequent uses? If the light comes on only once, I wouldn't worry about it. If it happens repeatedly, could be a weak igniter or a flame sensor that is on its way out.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 07-16-2019, 01:18 PM   #5
Mine, A DSI light comes ON temporary or initially until the pilot unit lights... Then the red light goes out and the water heats... with Gas. I think this is normal. for me anyway
gbaldwin is offline   Reply With Quote
Old 07-16-2019, 01:21 PM   #6
2012 Solera
X2 on the Sububan water heater in our 2012 Solera MH.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-16-2019, 02:24 PM   #7
bikendan's Avatar
The light should only come on temporarily. It's a problem if it stays on
Equalizer WDH
Old 07-16-2019, 02:33 PM   #8
wmtire's Avatar
This thread, particular the first post, and the #5 post will fully explain your DSI (which is only applicable to the propane burner)....as well as what the fault/reset lamp is for.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Words are powerful.
Choose them good.
