Old 02-05-2016, 10:06 PM   #11
mikejm
Will do.
mikejm is offline   Reply With Quote
Old 02-06-2016, 04:00 PM   #12
mikejm
All gfi's are good. Can't find were fireplace electric cord receptacle is or to see if that plug is good. Thanks, mikejm
Old 02-06-2016, 04:06 PM   #13
TURBS's Avatar
Pull your drawers out.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-06-2016, 04:14 PM   #14
mikejm
Found the plug, thanks! Unplugged, plug good, plugged back in, nothing. Is there another place to check?
Old 02-06-2016, 04:16 PM   #15
Left Coast
Gota be a plug....behind something...Did you check the plug-in for power/
Old 02-06-2016, 04:18 PM   #16
mikejm
None of the breakers are off but no chart for what breakers or fuse may give power to fireplace.
Old 02-06-2016, 04:21 PM   #17
Left Coast
PLUG a light in to know if there's power there at the plug....
Old 02-06-2016, 04:22 PM   #18
fonzie's Avatar
Some fireplaces are interlock with microwave so these don't run at same time. An auxiliary relay is use. Could it be a possibility in your case?
Fireplace shuts off when using microwave
Fonzie
Old 02-06-2016, 04:35 PM   #19
mikejm
No have used both simultaneously flipped that breaker anyway still no power to fp
breaker, electric
