Old 09-01-2013, 11:54 AM   #1
5 hole's Avatar
Electrical cord length on 36qbok?
Hello all, thanks for the answers to my questions so far as I prep my site for delivery.
One more follow up: How long is exterior power cord on this trailer? Need to confirm outlet placement and don't want to realize I am too far away from trailer.
5 Hole
5 hole is offline   Reply With Quote
Old 09-01-2013, 06:40 PM   #2
Iggy's Avatar
5 Hole
Standard minimums 25 ft
Old 09-01-2013, 11:42 PM   #3
Fulltime family RVer
So- when the camper is parked in front of my house, I have to run the cord from the plug connection point up along the camper to my 50-to-30 and then 30-to-20 adapters to where I plug in a heavy duty extension cord (12 gauge, I think). Those plugs are about where the basement hatch is. Between those 2 points is (guessing), 35'.
Old 09-07-2013, 03:10 PM   #4
I just measured. It's 35' long. The electric connection on the camper is about 6" from the back corner/20" or so forward of the back of the bumper.
Old 09-07-2013, 04:03 PM   #5
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
I just measured my 50 amp cord on my Surveyor and it's 28'. I have a question, however. I'd like to buy a 30' 30 amp cord for those instances where I need more length than the 28' FR provided. I only have one AC so if I need to run my RV on 30 amp I should be OK. Does this logic sound logical? A 50 amp extension cord is so expensive and heavy that I thought the 30 amp cord would be a sensible way to go. Comments please?
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 09-07-2013, 04:44 PM   #6
I'm sure others will have opinions- but being a new camper and being in a 50amp rig, I'm always a little surprised at how easily we trip the breaker at the campground box. What I would be worried about- with a 30amp cord, will you unknowns got exceed its ratings?
Old 09-07-2013, 05:09 PM   #7
As long as you're talking about plugging that into the 30-amp outlet in the pedestal and then using your adapter to take the 30-amp cord outlet into your 50-amp cord, you're fine.
You should not use an adapter to plug that 30-amp cord into the 50-amp outlet at the pedestal.
Old 09-07-2013, 05:28 PM   #8
Lloydg's Avatar
I would only plug into a 30 amp service with the configuration that I suggested. Thanks for both the replies.
Old 09-07-2013, 06:14 PM   #9
That sounds good to me, then.
Old 09-07-2013, 09:07 PM   #10
I have purchased another 15' exetension to carry in the rig, and have needed it a few times already. But here is another plauseable alternative I may explore. I have considered wiring another 50 amp plug in to the front of the RV that the power cord would connect into.
The batteries and transfer switch are both in the front of the RV, so the wiring should be fairly simple. I just haven't pulled the trigger yet.
SargeW is offline   Reply With Quote
electric, electrical
