Old 10-19-2014, 05:06 PM   #1
Unhappy Electrical outlet question
I bought my 325RL last month. It has been at CW for warranty repairs longer then it's been in my yard.
Two issues holding everything up. No 110 juice to the bedroom tv outlet. Does anyone know where the downstream run comes from. It's probably a bad connection at this box? not feeding juice upstream.
second my satellite in feed works in the living room but no were else. apparently this is a common issue across the RV industry.
smorg is offline   Reply With Quote
Old 10-19-2014, 05:21 PM   #2
Start at the circuit breaker then check every thing in that circuit. If it is a loose wire you will find it that way. It is possiable that a bad wire was installed or a bad receptical.Check both plugs in each receptical in that circuit.
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 10-19-2014, 05:56 PM   #3
TURBS's Avatar
Check all you gfci outlets.
Normally there all daisy chained together.
One in bathroom one in kitchen.
Normally satellite feed is to main living area only.
Turbs
Old 10-19-2014, 06:31 PM   #4
Dazed & Confused
M&K Hoffman's Avatar
The person doing our walk through pointed to a jack labeled something like "bedroom satellite" which is next to the game ports at the living room TV and stated that in order to get a satellite signal into the bedroom it had to be jumped into that jack. Other than that I can add no insight.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
electric, electrical
