Old 07-02-2019, 11:56 PM   #1
Empty Hidden Space in Puma 28RKSS
Anyone have a Puma 28RKSS and know if the rear corner under the kitchen counter top is empty space? I haven't had a chance to take off the panel inside the base cabinet yet to take a look, but if it's empty, I am thinking about adding an access door on the outside. If it is empty, it would be about a 2x2x3 tall space.
Snow is offline   Reply With Quote
Old 07-03-2019, 06:32 AM   #2
rmac04401's Avatar
I canít help you with that particular model but I did find a cubbie unused space under my refrigerator in my 27qbcClick image for larger version
ID:	208812Click image for larger version
ID:	208813Click image for larger version
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 07-03-2019, 03:14 PM   #3
Head Rambler
Looks like that space is almost the same as our 29RKSS. If so then that space has the water heater in it. There's a large space above the water heater that's wasted, but I haven't figured out how to make use of it yet. If you do, please post how you did it.
EDIT: Looks like yours may have the furnace in that space instead of the water heater.
Gotta go campin!
Old 07-03-2019, 05:14 PM   #4
rmac04401's Avatar
That is the breaker box. Furnace under stove, and water heater under corner cabinet
2005 Honda VTX 1300
Old 07-04-2019, 04:43 PM   #5
yes you can
I have 2019 puma 28rkss and did just what you want to do. Dealer installed door, the space is empty, except for the
1 1/2 kitchen sink drain that runs along
the back then turns and goes into thin
cabinet next to fridge and into galley
tank. I store grill, table, 2 collapsible
trash cans
Out of Plumb is offline   Reply With Quote
Old 07-04-2019, 06:53 PM   #6
3oRKSS
I have a 30RKSS and the area under the corner of the counter is taken up by the hot water heater and all the hoses going to and from it. It's a rather cramped area to get into even to winterize.
bobstepsup is offline   Reply With Quote
Old 07-04-2019, 07:14 PM   #7
Space Above Fridge
I know not all fridge models or how/where they're installed are the same, but I'm sure what we have is not unusual, ... I found a great usable space above our fridge, ....
ID:	208973   Click image for larger version
ID:	208974   Click image for larger version
ID:	208975   Click image for larger version
ID:	208976   Click image for larger version
fella10 is offline   Reply With Quote
Old 07-05-2019, 09:47 AM   #8
2019 puma 28rkss
My water heater and water pump are in
cabinet under kitchen sink and heater is
under oven. I was under the impression it
was that way because if you ordered it
with optional micro outside kitchen, they
filled that space, if not , it was left empty.
I know my 2019 28rkss the space was
empty and I made use of it. Hope this helps
Old 07-14-2019, 09:32 PM   #9
trash cans
Cool, do you have any pictures? And how much did the dealer charge you? Thanks a bunch.
Old 07-14-2019, 09:59 PM   #10
Just found pictures of the door and micro kitchen option. Looks like a lot of usable space since I don't have the kitchen.
puma
