03-09-2012, 07:55 PM
Extended warranty on palomino
Dose anyone know if Palomino offer an extended warranty
Comes with a one year from factory !
03-09-2012, 08:09 PM
You can buy an additional year within so many days of purchase.
03-09-2012, 08:11 PM
Through the dealer or factory direct ... I would image the dealer ?
03-09-2012, 08:13 PM
Through forest river.
I amagine the dealer can get u the paper work
I think you can do it online through fr
03-09-2012, 08:14 PM
Thanks for the great info
03-09-2012, 08:18 PM
I think you can get it direct from the factory.
At least that is my understanding from reading
here on the forum, a wealth of information to
say the least. Thanks to all who help us less
informed.
Mark And Libby
2011 F-350 4X4 Super Crew
2015 Cedar Creek 38FB2
Brampton ON.
03-09-2012, 09:30 PM
03-09-2012, 09:33 PM
Originally Posted by Wiscampsin
Thanks ...,,,, do much !👍
03-10-2012, 10:38 AM
I wish I had known about this when I purchased. I was not aware of it but would have purchased it. It is not mentioned anywhere in the documentation I received. Mine has been in for several warranty items and my first year is almost done. I would definitely recommend it.
2012 Sabre 32QBTS - Triple slide bunk house, Propride 3P Hitch
2005 Excursion - lifted and heavily modified
03-10-2012, 10:42 AM
What model do you have ... Just curious on what issues I should look out for
03-10-2012, 11:04 AM
I have a 2012 32QBTS travel trailer. Warranty issues. I upgraded to dual pane windows and a few of them did not open and close correctly - one would not latch shut and had to be replaced. Water pump would cycle on and off because of a bad check valve in the pump and needed to be replaced.
I bought it in the winter and was pulling it home across the country and camping in it on the way home and the furnance would run almost continually with not much heat. I pulled the return cover and noticed that one of the output duct block off plates (used when duct work is not attached) was missing so the hot air output at the furnance was just blowing out at the furnance and right back into the intake. I bought a piece of sheet metal and cut it to match and block off the opening which solved the issue. Six months later and the furnance would just quit working. Brought it in for warranty and the found a loose wire up in the A/C unit.
Now it is in for a rear bunk slide-out that is catching and not going out.
These issues could happen to any model. All but the water pump could have been avoided by better quality control and slowing down on construction. Seems to be pretty typical in the RV industry.
Overall I feel Sabre is high quality. I seem to be having worse luck than most.
03-10-2012, 11:11 AM
Well that's a few issues , its good that your handy and have common sense, the last issue sounds expensive or a headache .. I will definitely ask the dealer before picking up the unit and will contact forest river about the extended warranty ..
Good luck with your slide out
03-10-2012, 04:39 PM
You have to ask the dealer about the optional 2nd year warranty available through Forest River...they may not tell you. The dealer usually has their own multi-year extended warranty that they try to talk you into purchasing.
Dave
03-10-2012, 04:53 PM
Dave
my dealer didn't offer fr warranty or any other warranty .
kinda wish Id have known then .
03-10-2012, 05:19 PM
I would becareful, It's say's it will not cover normal wear and tear only org. defects. Very gray area. I purchasted a Cornerstone warranty for 7 years, if something breaks they will replace it, even under normal wear and tear.
