Old 06-06-2017, 06:28 PM   #1
Puma 2015's Avatar
Fan moter
My bathroom fan moter in my 2015 puma only works sometimes when you let the electric awning up or down
Puma 2015 is offline   Reply With Quote
Old 06-06-2017, 06:47 PM   #2
SYE
SYE's Avatar
Awning or vent cover???
Sent from my XT1585 using Forest River Forums mobile app
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 47 reserved
SYE is offline   Reply With Quote
Old 06-06-2017, 06:53 PM   #3
Puma 2015's Avatar
My bathroom vent moter works now and then
Old 06-06-2017, 07:06 PM   #4
Just as confused as you
Scrapper's Avatar
My bathroom has 2 light switches. One switch turns on the lights above the sink. The other switch turns on the ceiling light and the fan. The ceiling light has a switch on it so I turn it off and just use the wall switch to turn the fan on and off.
Check that your fan and light is set up the same way. Maybe someone has the light on at the same time your running the awning. If that is not the case then you may have a short between the awning and fan.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 06-06-2017, 07:12 PM   #5
Puma 2015's Avatar
Mine has two light switches then a switch for the fan all on the wall the push button on the fan is on
fan
