Old 03-22-2015, 08:50 PM   #1
Fell in Love with my RS320 Again
Spent the weekend on the Sacramento Delta with family. The weather was PERFECT. Grilled a Tri Tip and ate inside. There were 6 of us and being able to move the island and use it as a buffet table was great. This is the best RV I've ever owned. Added some insulation to the front cap but that's another post.
Fred & Christine
2013 Columbus 320RS
2016 F250 Lariat 4X4 Short Bed
2015 Nights Camped 72
2016 42
2017 15 so far
Fred and Christine is offline   Reply With Quote
Old 04-05-2015, 07:29 PM   #2
I also added insulation in the front cap of our 320. It made a nice improvement.
Wayne & Sheryl
Plus Ollie & Sophie
(they don't know they're dogs)
2011 Ram Laramie 2500 CC 4X4 6.7 Cummins
2015 Columbus 320RS
"Where ever you go, there you are" Buckaroo Banzai
Goukcats is offline   Reply With Quote
Old 04-05-2015, 10:05 PM   #3
Barefoot68's Avatar
How did you add insulation to front cap??
Barefoot68 is offline   Reply With Quote
Old 04-06-2015, 04:50 PM   #4
The foil was Reflextic from Lowes. Used a 24"x 25' roll and attached it using a staple gun. We did the closet with the sliding doors up to the roof line and the closet that's plumbed for a washer dryer. We also did all the cabinets and ceiling on the entertainment center slide including behind the tv. It has made a huge difference in keeping the bedroom cool.
Fred & Christine
2013 Columbus 320RS
2016 42
2017 15 so far
Old 04-06-2015, 09:37 PM   #5
lgray's Avatar
Any pictures?
lgray is offline   Reply With Quote
Old 04-10-2015, 10:19 AM   #6
Sorry, I can't find my photos. The foil may be an easier install. I used insulated foam board. I believe it is R10 rated. I attached it to the metal studs behind the front closet with self tapping screws (with large washers to prevent busting through the foam) & Grab it chaulk. I also covered each seam (where foam board pieces joined) with foil duct tape. I covered the entire wall cutting to fit at the ceiling & I covered the exterior of the access box (using Grab it) with a thinner foam board that did not exceed the thickness of the box frame. This allows removing the access box with no issues. The interior of the entertainment center cabinets gets very warm on hot days so I plan to copy Fred & Toni's idea using foil there. Regardless of the method you choose, it is beneficial. I left the hanging fiberglass insulation installed at the factory but it has many large gaps & is quite useless (in my opinion).
Wayne & Sheryl
Plus Ollie & Sophie
2015 Columbus 320RS
Old 04-15-2015, 06:25 PM   #7
Smoker's Avatar
Insulation
Yes, if all those Columbus owners only new that the front of their unit has literally zero insulation. I too discovered this when I had my front cap replaced. What a disappointment! I ended up removing a cabinet in my front closet, cutting insulation foam sheets and using sealant and aluminum tape to completely seal everything. It was a lot work but has made the bedroom much more comfortable.
2014 RAM 2500 4X4 CC 6.7TD
2015 Columbus 295
18K PullRite SuperGlide
Firestone Ride-Rite Air Bags
40 Gal AUX TANK
Smoker is offline   Reply With Quote
Old 04-18-2015, 10:55 PM   #8
Sorry this took so long, we were out on the Colorado river for the past couple of weeks. First time posting pics, hope they come out ok. Here are the cupboards on the entertainment/kitchen side and the closets on the cap.
Name:	Calico, Emerald Cove, Garth, Christine 512.jpg
ID:	74650   Click image for larger version
Name:	Calico, Emerald Cove, Garth, Christine 513.jpg
ID:	74651   Click image for larger version
Name:	Calico, Emerald Cove, Garth, Christine 514.jpg
ID:	74652   Click image for larger version
Name:	Calico, Emerald Cove, Garth, Christine 515.jpg
ID:	74653   Click image for larger version
Name:	Calico, Emerald Cove, Garth, Christine 516.jpg
Fred & Christine
2013 Columbus 320RS
2016 42
2017 15 so far
Old 04-19-2015, 08:34 AM   #9
lgray's Avatar
Thanks for the Pic's
Old 04-21-2015, 11:59 AM   #10
lgray's Avatar
Did you also insulate the back of the sliding doors and wall beside them in the cap closet?
