Old 08-05-2015, 04:43 PM   #1
MacDR's Avatar
Floor Bounce in 5th Wheels
I have a 2014 Columbus 340rk with the standard 4 point leveling system with stabilizer bars..I want to add 4 more scissor jacks one behind and one in front of the trailer Tire's on each side to firm the unit up and get rid of the bounce.. Do I just measure equally and divide the distances to the standard levelers or keep them closer to the tires..
Thanks for your thoughts
2013 Ram 2500 "Cummins"
2014 Columbus 340RK
28 Days camping 2015
2014 Columbus 340RK
Day's Camped 2018 "14"
You can find us: Egg Harbor Campground 7/9 - 7/11
MacDR is offline   Reply With Quote
Old 08-05-2015, 04:50 PM   #2
Crockett's Avatar
i think divide equally but realize that those distances are not cast in cement. convenience should play a role in location.
Crockett is offline   Reply With Quote
Old 08-06-2015, 11:03 AM   #3
amxpress's Avatar
When you say stabilizer bars, are you referring to JT Strongarms? If so, are you following the instructions they provide on how to set them up? When set up properly, my 320RS is pretty stable.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 08-06-2015, 11:26 AM   #4
MacDR's Avatar
Yes, I have ... It really doesn't make a difference of concrete, gravel or grass..my 50 lb. granddaughter walking inside gets a bounce..
Greetings from Wisconsin
2014 Columbus 340RK
Old 08-06-2015, 11:29 AM   #5
MacDR's Avatar
I'm also thinking of a set of those X type expandable Tire chocks might help..
2014 Columbus 340RK
Old 08-06-2015, 11:44 AM   #6
B and B's Avatar
X Chocks stop the for and aft movement. JT Strong-arms stabilize the trailer front to back further and on the Landing Gear side to side. Think of the landing gear being silts. Our Fifth Wheel is stable now.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 08-07-2015, 07:10 AM   #7
jevanb's Avatar
I use home made JT'S, tripod, slide stabs, and I still get movement but with 4 Slides and 4 kids it is expected..
Sent from my SCH-I545 using Tapatalk
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 08-07-2015, 07:38 AM   #8
Putting jacks in front of the axles will stop the bouncing floor that will not be eliminated with X Chocks or JT Strongarms.
Old 08-07-2015, 11:55 AM   #9
First trip with X-Chocks and tripod and it really helped a lot. Pleasantly surprised me. Additional benefit of the tripod it took away 80% of the squeak in the bedroom floor.
2017 Grand Design Reflection 367BHS 5th wheel.
2017 F350 crew cab 6.7 4X4 srw.
clicker1944 is offline   Reply With Quote
Old 08-11-2015, 07:11 PM   #10
Why not spend some $$$ and have 3rd set of leveling jacks installed in front of the wheels? Sounds like too much frame flex. That long of a 5er should have 6pt leveling.
goduc is offline   Reply With Quote
5th wheel, wheel
