Old 01-20-2015, 08:55 PM   #11
TURBS's Avatar
Originally Posted by MillerTime View Post
Mine is just like turbs pics.
My low point red and blue have caps on them and are further back.
Correct
Old 01-20-2015, 08:56 PM   #12
Fulltime family RVer
Originally Posted by TURBS View Post
First one is from side second is from the back looking forward.
Same here. Except for my low point drains, I put quarter-turn ball valves on them after I lost one of my caps.
Old 01-21-2015, 03:21 PM   #13
BuckeyeChuck's Avatar
Same as as all above. One picture is worth a thousand words.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 01-21-2015, 04:14 PM   #14
BuckeyeGal
Sabre fresh water drain location
I had same question for our 2012 31-CKTS-6. I found the 1/4 turn valve located just above the front axle on left side of trailer.
Terry & Carol
2012 Sabre 31-CKTS-6
2003 F-250CC 7.3L Powerstroke
buckeyegal is offline   Reply With Quote
Old 01-26-2015, 02:51 PM   #15
When I drained my fresh water as said earlier, my fresh water level went to Zero. When I tried to refill, all I could put in was about 15 gallons with the water level showing 2/3!
BTW, it's in for warranty work as you read this. I'll let the dealer figure it out. One of the techs mentioned something about a vent???
mikezjr is offline   Reply With Quote
Old 01-29-2015, 11:40 AM   #16
Redleg13's Avatar
On my 2014 QSIK it looks exactly like Turbs and located center mass under the left side of the basement access door.
Redleg13 is offline   Reply With Quote
Old 01-30-2015, 05:04 PM   #17
Redleg13, is that Elizabethtown, KY aka E-town??
Old 02-08-2015, 06:12 PM   #18
Coolharts's Avatar
Installed 2 metal lever valves on mine today after I found the fitting not sealing on the red tube. The tubes between the axles is not the easiest to get to and the lever valves make it easier when laying on my back.
2017 Surveyor 33RETS with Residential Refrigerator and Inverter
2005 Ford Excursion 6.0L 2WD
Nights Camped 2016 27, 2017 29
Nights Camped 2018 4 Scheduled 25 (so Far)
Coolharts is offline   Reply With Quote
Old 02-23-2015, 03:30 PM   #19
Warranty work
Got my sabre back from its first trip to dealer for warranty work.
1. Fresh water drain installed by dealer. They even managed to duplicate the custom black sealant application as provided by the manufacturer!
2. Replaced a vent that allows one to top-off fresh water tank.
Is there any sort of maintenance manual out there that includes system descriptions, or do owners have to take things apart by themselves?
I should know this! this is my 4th 5th wheel!! What am I thinking about!!!
cat, drain, fresh water, location, palomino, sabre, water
