Old 09-15-2016, 01:47 PM   #1
Fridge Cooling
I have been reading all the recent posts about fridge cooling on this site. I decided to look at mine before heading to storage. When I popped off the top vent cover I had that piece of wood to direct airflow and a small muffin fan. My fridge is in a slide and I have slide toppers. I do not have time to install some fans before I go out in a couple of weeks. There was a rather thin piece of insulation just laying over the top and down the sides of the fridge. I would say there was 6 inches of open space above the insulation to the top of the slide. I stuffed some insulation I had from construction on the top (Now there is no air space) and along the sides. My thinking is air flow should be drawn up and out the vent so stuffing the insulation should not hurt anything.
Anyone see any issues with this?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-15-2016, 02:26 PM   #2
Head Rambler
Can you post a pic of what you did?
The airflow should flow across the cooling unit, and the more flow over the unit the better, so if what you did stopped airflow in the empty space around the cooling unit, it sounds like you did a good thing.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 09-15-2016, 02:47 PM   #3
Pictures
Pictures Attached
ID:	120313   Click image for larger version
Old 09-15-2016, 03:11 PM   #4
Head Rambler
I'm not sure that's going to help much, but it doesn't look like it's going to hurt.
And hey, we know with these fridges; every little bit helps.
Gotta go campin!
Old 09-15-2016, 08:11 PM   #5
Thanks for the reply. Any little bit helps
cooling, fridge
