Old 10-17-2014, 11:39 AM   #1
BuckeyeChuck's Avatar
Front cap lights
How do I replace the bulb in my front cap decorative lights (amber). I'm not sure how to remove the lens.
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
Old 10-17-2014, 11:41 AM   #2
Forgot....it's a 2013 Sabre 33ckts.
2013 Sabre 33CKTS
Old 10-17-2014, 11:41 AM   #3
Ret E-9 Anchor-clanker
donanddona's Avatar
Can you post a picture? Most are, if you can not see the screws then they pop off.... careful not to chip the lens...
donanddona is offline   Reply With Quote
Old 10-17-2014, 12:01 PM   #4
TURBS's Avatar
Chuck I think there led no ?
Turbs
Old 10-17-2014, 01:27 PM   #5
They are led. There are six of then. Three on each side of a V pattern. I'm not sure if they will pop off. I'm hesitant to try in this cold weather I'm afraid the plastic will be brittle.
2013 Sabre 33CKTS
Old 10-17-2014, 01:39 PM   #6
TURBS's Avatar
Chuck I've only looked @ them briefly but do they have a small rubber mounting grommet around them?
BTW you'll have to replace the whole fixture or unit as shown.
DO NOT DO THE WIRE INSIDE THE CAP WHEN YOU CUT IT!
Turbs
Old 10-17-2014, 02:50 PM   #7
TURBS's Avatar
Chuck, I have confirmed that they are held in buy little rubber grommets.
Take a flat blade screw driver and pry out led assembly and rubber grommet.
Be careful not to chip fiberglass.
Turbs
Old 10-20-2014, 06:47 AM   #8
Thanks. That indeed the light I'M refering to. Is there a plug on the end of the wire? I'll probably need to order the light from the service dept.
2013 Sabre 33CKTS
Old 10-20-2014, 06:51 AM   #9
TURBS's Avatar
It may be a connector or it may be spliced with a twist cap.
I've gotten these lights as pictured above from any HD trucking supply place such as www.midwestwheel.com
Www.grote.com
Turbs
Old 10-20-2014, 09:02 AM   #10
Thanks for the replies. I will probably remove it next spring when it warms up. My Sabre is going inside for the winter today. It was a great summer but as usual way too short. Can't wait to become a snowbird in a couple of years.
2013 Sabre 33CKTS
light
