Old 09-14-2015, 08:00 AM   #1
Kidtexas's Avatar
Front slide is it all the way out
Just noticed on my 320 RS that it looks like the front bed slide may not be all they way out. when you look at it the rubber gasket with the slide out its on the window trim still, I would think it should be at least past the window trim by an inch or so. the inside looks like it could gain one more inch so not sure. Anyone with a 320 RS does the rubber slide gasket make it past the window trim?
2006 Ford F250 4x4 Amarillo Edition, 6.0 Turbo
2015 Columbus 320 RS
Kidtexas is offline   Reply With Quote
Old 09-14-2015, 10:07 PM   #2
amxpress's Avatar
Is there a gap inside the bedroom between the wall and slide molding? You should only be able to get your fingers between them and feel the seal of the slide contacting the wall. If not, then your slide is not fully extended. I have a Scwintek bedroom slide which I don't think they use anymore.
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
amxpress is offline   Reply With Quote
Old 09-15-2015, 07:06 AM   #3
Kidtexas's Avatar
Amxpress, there is about that much but maybe just a bit more, I just thought it was strange to see the rubber gasket on the outside laying halfway on the window seal, I will try and post a photo tonight and it is an electric slide, no leaks so it may be normal. thanks for the reply.
Old 09-15-2015, 07:15 PM   #4
The window rubber does go out past the gasket. The slide out has not set up right.
seahawk986 is offline   Reply With Quote
Old 09-15-2015, 07:48 PM   #5
Kidtexas's Avatar
Thanks Seahawk I thought that was not normal.
Old 09-16-2015, 01:43 PM   #6
Here is a photo of my bedroom slide on the same Columbus model RS320.
If you read the Lippert manual it tells you how to adjust the slide so it will extend farther out. I think you can also get information on Lipperts website or call them.
Wishing you the best!
10Penny is offline   Reply With Quote
Old 09-16-2015, 02:36 PM   #7
Kidtexas's Avatar
10 penny thanks I will go through the manual and see if I can find it.
Old 09-16-2015, 03:07 PM   #8
Kidtexas's Avatar
Penny, I dont see the photo...
Old 09-26-2015, 08:12 AM   #9
BuckeyeChuck's Avatar
No photo...?
2012 F250 Super Duty
2013 Sabre 33CKTS
BuckeyeChuck is offline   Reply With Quote
slide
