Old 10-11-2012, 11:27 AM   #1
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Front Storage Key
When we got our 320RS we received two keys to lock the door and two keys for storage locks.
The storage keys work great for the left and right side storage, but the "front" storage (under the 5th wheel hitch) uses a different key.
My dealer has been unable to get me a key that will lock it and Forest River/Palomino has sent me TWO different keys (separate times) and neither of them work.
They first sent a double-edge key, but it appears the front storage latch takes a single-edge.
So, they sent a single-edge key, but it doesn't work either.
To my fellow Columbus 320RS owners - do you have a key that will lock that front storage? If so - what is the key number that is stamped on the key.
For security reasons if you'd prefer to send me your key code via private message here in the Forums that's fine...I'm just anxious to find out what key works so I can secure my property in that front storage bin.
Thanks!
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 121
rjshiflet is offline   Reply With Quote
Old 10-11-2012, 11:43 AM   #2
B47
Thanks!
I have a CC Silverback FW and the key code for my front storage locker is CH751 and it is just about the same as having no lock or key at all.
I had our dealer in Cleburne change ours out after it came apart. The new one isn't much better.
There are posts about these locks and the infamous CH751 key.
Hope this helps.
o
Old 10-11-2012, 11:56 AM   #3
TURBS's Avatar
When I first got my palomino sabre the front lock didn't work either btw in fact the inside lever wasn't adjusted right and wouldn't allow the tumbler to turn.
I think you'll find you have the right key but either a bad lock cylinder or the locking lever is not on correct.
Ch751 should be stamped on the outer case.
Turbs
Old 10-11-2012, 01:04 PM   #4
"On the road again"
rjshiflet's Avatar
No - CH751 doesn't work. We had those left over from our Sandpiper. And the key that fits the front door and the side storage is definitely a two-sided key. The one for the front (it's a different design of slam-latch completely) obviously is a single-sided key like the CH751. But...CH751 won't work and the TriMark TM-242 (single sided that the Forest River guy sent) won't even fit into the lock.
The side storage doors don't use CH751 - they use a TriMark double-edged key.
Old 10-11-2012, 01:08 PM   #5
eisbell's Avatar
Sent a PM with the code on ours. The square one opens all compartments below and the round only the door. I sent you a PM with the code we have on ours. Jeane
eisbell is offline   Reply With Quote
Old 10-11-2012, 01:23 PM   #6
eisbell's Avatar
See photo below
Thanks!
Old 10-11-2012, 01:26 PM   #7
eisbell's Avatar
Something weird going on here - shows my post and photo but then it says my post is too short so here I will try again. Sent you a PM with code, square goes to all of our compartments below, round to door. Jeane
Old 10-11-2012, 01:28 PM   #8
FreedomTracker's Avatar
Where can you locate a store that has the proper blanks for the front locker storeage key?
I am interested in making a spare key b/c we lost our extra key on our last trip... tried local locksmiths, Walmart, Home Depot, Lowes & Camping World... the problem is they do not have the blanks to fit.
2012 Ford F150 4x4, 5.0L, 3.55
2011 Rockwood MiniLite 1809s
E2 WDH 600/6000lbs
FreedomTracker is offline   Reply With Quote
Old 10-11-2012, 03:39 PM   #9
"On the road again"
rjshiflet's Avatar
Got your private message - that is so strange because those keys look just like ours...except for us the SQUARE one fits the front door - and the round fits the storage underneath (sides only).
I wish someone at Forest River would at least tell me the key number and I could buy my own somewhere I'm sure.
Old 10-11-2012, 03:45 PM   #10
"On the road again"
rjshiflet's Avatar
I ordered some extra front-door keys from RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys and all I had to do was give them the key code and the make (TriMark, FIC, etc.). I even got a couple with a built-in LED light so it makes it easy to unlock in the dark.
Good, fast, reputable service - I'll certainly do business with them again (especially if I can find the key code for my front storage).
Old 10-11-2012, 03:54 PM   #11
eisbell's Avatar
Does your round one say Tri/Mark 2001?
Old 10-11-2012, 04:25 PM   #12
"On the road again"
rjshiflet's Avatar
Yes
Old 10-11-2012, 06:50 PM   #13
eisbell's Avatar
Well Ervin corrected me. Round to underneath. Hope you get it resolved our one keys does all of them. Maybe you can get them to send you a new lock for your code
Old 10-12-2012, 11:00 AM   #14
Mike Zeto
On our 320rs the round key works all the compartment locks.
mzetp is offline   Reply With Quote
Old 10-12-2012, 07:23 PM   #15
lgray's Avatar
Key
Round one opens all of ours.
lgray is offline   Reply With Quote
