Old 11-18-2013, 10:44 PM   #1
Can someone tell me where the waterline to the rear kitchen on my 340 columbus runs along
Bulldozer is offline   Reply With Quote
Old 11-22-2013, 09:29 PM   #2
It's 17 degrees here and my 340 kitchen faucet froze up today. We didn't run the water there all day and guess it would have been a good idea to have done that. I took the drawers out to the right of the sink and the lines go into the floor there. Took the drawers out and put a heater there so we'll see how it works. Good luck.
Jim & Linda
2012 Dodge 2500, Diesel (of course)
2014 Columbus 340RK
jeb182 is offline   Reply With Quote
Old 11-23-2013, 10:47 AM   #3
jtstromsburg's Avatar
I'm having the same issue in my Sabre 34TBOK. Running propane furnace only inside, to make sure heart is getting to underbelly. I have a small heater in the outdoor kitchen, and one right in the basement storage bay. Its nice in that bay, and great in the ok too. Any ideas? I'm thinking I'll have to wait for a warm day, and drop the underbelly cover to examine. Any other tricks?
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 11-23-2013, 10:50 AM   #4
Ford Idaho's Avatar
Trailer skirting with a heater near you docking station.
Old 11-23-2013, 10:58 AM   #5
I got the heater. The full story is...its sitting in my driveway. Usually would have winterized a couple weeks ago, but doing Thanksgiving with the dw family and was informed we are using the Sabre for the weekend. Last year, when I first brought the fiver home, it was much colder then expected and so we had to heat it then as well. I would definitely skirt it if I was living in it, but I'll probably winterize after next weekend. I'm just wondering why the lines are freezing up so easily? Maybe they are not above the insulation or maybe the insulation had moved and is allowing air in? Daytime temps are still under freezing, but back to the mid 40's after today I think. Live and learn I guess. We bought this, hoping to be able to use it for short, high propane use, winter stays (like for holidays and such). I plan to add shutoffs for the outside kitchen lines, but really thought the rest would work. I realize its not a true for season rig, and we would use plenty of propane to keep it from freezing up.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-23-2013, 11:09 AM   #6
Ford Idaho's Avatar
Cn you get water to run thru anything?
If you can run as much water thru the trailer as you can.
Outside shower or sink any and all that will run water.
Perhaps the water flowing will warm the pipes enough, even cold water is above freezing.
Old 11-23-2013, 11:21 AM   #7
Water everywhere Except at kitchen sink. It'll work by about 3 today I'd guess.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-23-2013, 11:48 AM   #8
Ford Idaho's Avatar
Does the faucet have a screen or aerator, could it be plugged?
I have seen posts where others have found plastic bits in screens and valves from construction.
Old 11-23-2013, 12:02 PM   #9
Good thought. It does have an aerator. Its a pull out style faucet, and I did pull it apart yesterday, but no luck. I an considering making a "trap door" under the sink, so I can pump gay into that area when needed. Not sure how I'd do it, but think I could since its always hidden under the trash can and a behind a cabinet door.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-23-2013, 06:07 PM   #10
Jimmerinwi's Avatar
Your going to pump WHAT into area?
Some days I wake "Grumpy", Some days I just let her sleep......(Ray Scott)
Jimmerinwi is offline   Reply With Quote
Old 11-23-2013, 06:23 PM   #11
Hmm. Well I was thinking heat, but I guess not. Pictures too follow.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-25-2013, 07:59 PM   #12
I decided to cut into the underbelly tonight. After making a "door" in the coraplast, I sliced through the "radiant insulation" and found the water lines right there? Hmmm. I was under the assumption there was also fiberglass insulation below the lines, but maybe not. If I am looking at it right, there is maybe foam insulation at the bottom of the decking? Maybe? I added some insulation below the lines. If nothing else, it should keep the pipes from sitting right on the radiant layer. They were also right against some steel framing member, which would transfer cold easily. Hopefully, this will help.
Joel and Teresa
2016 Sabre 34TBOK
Old 11-26-2013, 10:15 AM   #13
Phat Phrogs Incognito...
DutchF's Avatar
Would it be possible to slip some foam pipe insulation over the line(s)? I'm planning on going through ours and doing that, as soon as I get some time. It will also give me a chance to ensure fittings are tight and there are no sharp edges rubbing on anything.
Tina + Dutch and Bell, Bobo, Harley, Buddy (the dogs)
2011 F350 Lariat 4x4 DRW SuperCrew 6.7L (B&W setup w/Air Lift 5000 Ultimate)
2014 Columbus 365RL (Airflex and Voyager package)
Nights Camped 2014 - 154, 2015 - 32, 2016 - 4
DutchF is offline   Reply With Quote
Old 11-26-2013, 10:20 AM   #14
Good idea. At this point, unless I can fund a friend with open tall shop space, I'll wait till next spring when it warms up. Then, drop the whole bottom and re do insulation as needed, maybe adding more and definitely sealing up spots.
Joel and Teresa
2016 Sabre 34TBOK
