Old 12-04-2018, 01:14 PM   #1
Furnace stopped working
Howdy y'all! I just signed up because we have just had our first issue with our camper. We were in Flagstaff AZ for thanksgiving and our last night there our gas furnace stopped coming on. We have a 2018 Columbus. We still have propane, and the one fuse that I found was not blown. Do any of you have any suggestion on were to look?
On a side note the electric furnace just blows cold air through the AC ducts. Thanks for the help!
Columbo 5 is offline   Reply With Quote
Old 12-04-2018, 01:19 PM   #2
koller1509's Avatar
Try shutting the thermostat off for 30 seconds then back on. The other often overlooked thing is the high temp limit switch might be stuck open. it should be on the end where the ducts hook to furnace. Try jumpering it out or smack it hard in the center.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 12-04-2018, 02:53 PM   #3
bikendan's Avatar
Are you talking about the heat pump because RVs don't have electric furnaces.
The furnace uses only propane for heat but it needs 12v battery power to ignite and to run the fan.
The heat pump requires shore power to run.
Equalizer WDH
Old 12-05-2018, 11:01 AM   #4
I have turned it off and turned it back on and that did not fix it. That should be on the back of the furnace correct? So I will have to go through the wall in the basement (as my wife and I call it)?
Old 12-05-2018, 11:09 AM   #5
I guess that is is a heat pump then. The units that the company that I work for our heaters are in the AC unit but all it is, is an electric strip that heats up. So that it warms the air up as it passes by.
Old 12-05-2018, 11:09 AM   #6
koller1509's Avatar
Yes
Larry
Old 12-05-2018, 12:52 PM   #7
bikendan's Avatar
Yep, that's the only electric heat source unless you have a fireplace or you buy a separate heater, like a ceramic or oil-filled heater.
Equalizer WDH
Old 12-05-2018, 01:34 PM   #8
Flybob's Avatar
Most heat strips in AC units are really not heaters, but rather chill chasers. They will help take the chill off on a cool morning, but usually not do much to heat an RV in cold weather.
Did one tank run out of propane and the furnace stopped and then you switched it tanks? If that is the case, you may have tripped the fail-safe mechanism. If so you have to remove the 12V to the control board wait a minute then reapply. On some units, this can be accomplished via the thermostat on others you may have to remove the furnace fuse.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 12-06-2018, 09:51 AM   #9
I did remove the fuse to check it when we got back I didn't think about it while we were gone. I have not tried it since I removed the fuse. I don't think that I ran out of propane but a few day prior I did and had to switch the bottles. I will try that because that is easy to try then the first suggestion.
On the heat strip in the AC. When you say take the chill out of the air what do you mean. The last time I tried to use the electric heat it was 58 in the camper and with in a minutes or 2 it dropped it to 56 so I turned it off and the fireplace warmed it back up.
Old 12-06-2018, 10:11 AM   #10
waybeck2018
waybeck2018's Avatar
Heater Questions
Due to theft of my propane cylinder I now plan to remove them at trip end and store in my shed. Question: Best way to purge air from the system once I re-install the tank and use the stove, furnace, etc? Thanks for hints/advice in advance.
waybeck2018 is offline   Reply With Quote
furnace
