Old 01-17-2018, 01:07 PM   #1
Furrion 30amp Plug
Hello all Just got me a new trailer 2017 202rb Solaire and when it is hook too shore the 30 amp blue light is on on the male side but on the door flap on the camper side there is no led lit. I have power in camper so not a problem. Shouldn't it be lit? Is this common not too be? Or is it not lit telling me i have a problem. Shore power is at home and was wired by a professional electrician. I have a smal ground and power tester for my 30 amp outlet and that says its ok. Any thoughts?
Thank you ahead of time.
rlhul699 is offline   Reply With Quote
Old 01-17-2018, 01:12 PM   #2
rlhul669, 2nd post... Welcome!
It is very common for those LED indicator lights to burn out.
Many posts here about them not working.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 01-17-2018, 03:33 PM   #3
The wires to the LED are very thin and and tend to break inside the insulation due to flexing. Mine lasted a couple years before a wire broke. I looked at fixing it but after seeing how it was put together decided it wasn't worth the effort.
Edit: Just noticed you have a 2017 so if it is still under warranty I would take it into the dealer to replace the connector.
keith_h is offline   Reply With Quote
