Old 03-10-2014, 08:48 PM   #1
Are we there yet.......
Pbalmer65's Avatar
generator!!
Could a person replace the spare tire with a generator on the 36qbok? Oh!!! And have it work. Thoughts!!
Pbalmer65 is offline   Reply With Quote
Old 03-10-2014, 08:55 PM   #2
TURBS's Avatar
Oh I would be leery about this.
Do you have the factory mounted rack on the back ?
Old 03-10-2014, 08:57 PM   #3
Pbalmer65's Avatar
My spare is up front in a drop box behind the front hitch door.
Old 03-10-2014, 09:03 PM   #4
TURBS's Avatar
ok so similar to my unit.
I think there are many reasons why I would not.......
Vibration.
Heat.
Potential fire hazard.
Heat build up inside of closed space.
Noise.
Carbon monoxide build up.
Old 03-10-2014, 09:09 PM   #5
Pbalmer65's Avatar
Well that's enough for me. To much work to take that chance.
Old 03-10-2014, 09:11 PM   #6
Oklahoma Proud
MillerTime's Avatar
I think I'd agree with turbs. My non -honda or yamaha genny is loud and stinky.
If needed id just throw it in the back of the truck
MillerTime- Future Sabre Handler!!
Old 03-10-2014, 09:15 PM   #7
Fulltime family RVer
Right, but lots of fifth wheels come with generator preps up in that area. What are they doing to prepare the area and could the OP replicate it?
Old 03-10-2014, 09:19 PM   #8
It can be done but the logistics of it turn most people off. You have to have a completely sealed off space around the generator, proper airflow to the gen, and then get all the wiring done with transfer switch and such. When you add all this up, carrying a portable generator seems easy.
maxum1989 is offline   Reply With Quote
Old 03-10-2014, 09:48 PM   #9
Pbalmer65's Avatar
If I was to do that what quite generator is out there (portable) to run a 50 amp 5er? I have a 6800 now but it's a OHV and not so quite. Also real damn heavy......
Old 03-10-2014, 10:37 PM   #10
Both Honda and Yamaha make big inverter generators. 6500 and 6300 watt respectively. They are about as quiet as you will find. I think they weigh around 200 pounds though. I don't know if you would consider that "portable".
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 03-10-2014, 11:17 PM   #11
ironj's Avatar
i recently acquired the beast of the 6500is.......it will run my 15k ac just fine......actually if i stagger the starting it will run them both...but i would venture to guess that full of fuel its closer to 300lbs!!!!...and with the height of my lifted f250 tailgate and recently repaired shoulder/rotator cuffs, its quite a handful....had to use my aluminium bike ramps to struggle it in last time....so its portable per se...........but man....its borderline...LOL
Sent from my Transformer Prime TF201 using Forest River Forums mobile app
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 03-11-2014, 09:32 AM   #12
TURBS's Avatar
I have a 6875 Honeywell "several hunderd lbs"
I use this to put it in the back of the truck.
I also use it to install my slider hitch.
There cheap at harbor freight and you wouldn't believe what you'd use it for.
I have not pulled a motor since I gave up stock car racing 5 years ago.
Works great to lift the back of the snowmobiles to.
Just sayin.
TURBS
Sabre owners united!
