Old 11-30-2012, 10:08 AM   #1
GFI Problem
Hi all, I took delivery of my new 365RL a couple days ago in Florida. Everything
was going well until last night. I noticed during the night that the night light in the bath room was not lit. I figured it was just the bulb. This morning I find that all the receptacals that are on the GFI circuits are also not working. I try to reset the main GFI breaker, re powered the AC power, no luck. I also notice that the fridge is now running off propane instead of AC. It is on auto mode, but is not detecting AC power. Any suggestions before I call someone, Everything was working normal before this.
WRROST is offline   Reply With Quote
Old 11-30-2012, 01:38 PM   #2
Dave_Monica's Avatar
Doesn't sound like you have any 120V power. Have your checked the main 120V breaker in your panel or at the campground post?
Dave
Old 11-30-2012, 11:40 PM   #3
TURBS's Avatar
Also your lights should be 12v not 110v.
Old 12-01-2012, 07:32 AM   #4
GFI Problem Solved
Turns out the 50 amp connection on the post is defective, only supplying one leg. Connected to another post and everything back to normal,thanks.
